It is currently Mon Jul 07, 2025 4:28 am
[ 2 posts ] |
Anthonyaarnold
Joined: Thu May 14, 2015 7:43 am Posts: 174 Location: SLC, UT/ARK-LA-TEX bred
 Motor Wobble
16 hp Go-devil Long tail (short shaft - 58")
Ive noticed that my motor has gotten real wobbly on the transom. I just give the tiller a little budge and the motor wobbles back and forth.
I tried tightening that bolt right under the u-joint on the swivel bracket and it wouldnt budge, maybe I just wasn't giving it enough elbow grease..? 1) Could the wobbling of the motor have to do with prop depth being off?
2) Any recommendations on getting motor to stop wobbling/ prop depth set right?
Seems self explanatory typically when somethings loose it just needs to be tightened but the only thing I could see to do was to tighten the bolt on the swivel bracket.
_________________ 40 Go Devil FNR on 20x48 WC Custom --
Mon Sep 21, 2015 8:43 am |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
 Re: Motor Wobble
Is your handle tight? The four bolts under the engine plate? I've had those vibrate off before and feel "wobbly".
Mon Sep 21, 2015 9:07 am |
[ 2 posts ] |
Users browsing this forum: No registered users and 47 guests |
