Rattle on a gt can't find http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=64327 |
Author: | genson [ Wed Oct 28, 2015 11:07 am ] |
Post subject: | Rattle on a gt can't find |
I've got a rattle that I can't find and its only under load I have removed all the sheet metal on the engine clutch cover bearings feel alright ... Just wondering if anyone else has had this problem nothing is loose anywhere can't get it to do it out of water |
Author: | MaXXis85 [ Wed Oct 28, 2015 12:33 pm ] |
Post subject: | Re: Rattle on a gt can't find |
Inspect your lower unit bearings for play. Thrust and lateral. |
Author: | cheniermudder [ Wed Oct 28, 2015 7:53 pm ] |
Did you check the muffler heat shield? |
Author: | genson [ Wed Oct 28, 2015 8:52 pm ] |
Previous owner had just put a brand new stock muffler and I changed it out with a q no diff made and the lu I have engine off right now so no belt tension on bearing can't feel any slack but does gt use bushings or bearing s |
Author: | mudxxed [ Thu Oct 29, 2015 4:44 am ] |
Not 100% sure how the clutch setup in on a GT. Maybe your clutch is rattling against the anti rotation bolt (worn down) if thats how GT setup works. |
Author: | Will [ Fri Oct 30, 2015 6:16 am ] |
It's a Gatortail, the bitch is gonna rattle. |
