It is currently Tue Oct 27, 2026 4:24 pm
Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
 GATORTAIL LOWER UNIT SEAL REPLACEMENT
Post GATORTAIL LOWER UNIT SEAL REPLACEMENT
Fri Oct 30, 2015 8:26 am
Post Re: GATORTAIL LOWER UNIT SEAL REPLACEMENT
Fri Oct 30, 2015 8:33 am
Fri Oct 30, 2015 8:50 am
Fri Oct 30, 2015 9:14 am
Fri Oct 30, 2015 9:24 am
Fri Oct 30, 2015 9:48 am
loctite.JPGSAFETY 1ST.JPG :lol: :lol: :lol:
Fri Oct 30, 2015 9:53 am
I'm gonna finish the rear seals tonight and take some more pics to finish this thread up. I hope this thread helps folks just trying to pay some back from all the help I get from this site.
Fri Oct 30, 2015 9:57 am
Nice thread doc! :geek:
1854 Prodigy DPE Level 3 HDR
Fri Oct 30, 2015 10:19 am
Thats a good write up. It will really help out many in the future.
Fri Oct 30, 2015 5:53 pm
Sat Oct 31, 2015 6:46 am
Sat Oct 31, 2015 7:02 am
Sat Oct 31, 2015 7:15 am
Thanks for the thread HS. I'm sure it will help someone in the near future. I can tell you from experience, loosening the motor mount bolts (not removing them) is the easiest way to get the belt both on and off. I was able to just push the cleaned up belt back down to the bottom of the belt housing (prior to mounting the outdrive) and slip it onto the front pulley once the LU is bolted back onto the BH. Then just tip the motor back and slide it over the top pulley.
I do have one question tho...are you sure the two rear seals go back in opposite directions? I'm pretty sure mine both came out facing inward (cup side toward the boat) and are slightly spaced apart from each other.
Sat Oct 31, 2015 10:18 am
Sat Oct 31, 2015 10:36 am
I'll PM Max. Have him read over the thread. He rebuilds these units all the time and helped me thru mine.
Sat Oct 31, 2015 1:05 pm
Sat Oct 31, 2015 1:41 pm
Or mine is wrong and I need to fix it!!!
Sat Oct 31, 2015 3:48 pm
I've always taken them out and re installed them both lips facing the prop. Basically you cannot over pressurize the lower unit. Grease can slip past seal but water cannot come in.
Really I doubt it will be an issue having them oppose each other.
Sun Nov 01, 2015 8:04 pm
Mon Nov 02, 2015 11:01 am
I don't blame you there. Just keep an eye for grease around that wear sleeve. If you're not changing grease through the season, it should be fine. But you may want to check it periodically to make sure it's not getting watered down. Thats just me tho....I tend to be anal about that crap.
Mon Nov 02, 2015 5:32 pm
All your answers to the way the seals should be installed are in previous threads. Next time take a sec to search. It would have saved you a lot of trouble. I do applaud you putting this together.
Tue Nov 03, 2015 9:34 am
Tue Nov 03, 2015 9:55 am
This is a great how to thread with an excellent title. Maybe this one will be easy for people to find when they search.Thanks again.
Tue Nov 03, 2015 7:43 pm
Sticky worthy. Mods?
Tue Nov 03, 2015 7:45 pm
Any suggestions on removing the front seal wear ring?... Mine doesn't want to budge..thinking about putting a torch on it..
Wed Dec 23, 2015 5:17 pm
If you're replacing it, just put a pipe wrench on it to get it turning, then some pliers, channel locks, or vise grips and tap the tool lightly with a hammer to slide the sleeve off.
If you're reusing because it's not worn, then a strap wrench or something to get a good grip like that should work.
Wed Dec 23, 2015 5:24 pm
I'll give it a shot..thanks
Wed Dec 23, 2015 5:29 pm
Put pipe wrench on it, got it to budge a little. Tried the vise grips and a rubber mallet, to beat it off. Still can't slide it down the shaft at all..thought about using some BP blaster under it. I'm worried I'm going to bend it and get it stuck on the shaft. Have you ever heard of someone having to cut it off?
Sat Dec 26, 2015 7:59 am
Subsrcibed. Thanks for posting!!
Thu Mar 03, 2016 7:34 pm
Thu Mar 03, 2016 7:47 pm
changing mine at the moment and cannot get the taper ring out of the pull, beat the crap the of out it with a rubber mallet, soaked it in pb blaster, put a whole lot of pressure on the middle allen wrench hole and nothing, even tried heating it up and nothing worked. any thing else to try ?
Delta lvl 3 GTR with MAC
16x54 Gator hull
Sun Sep 04, 2016 11:15 pm
Run the allen bolt in the remove hole, tight and they usually pop right off. If not, get it tight and smack the gear next to the taper lock. If rebuilt numerous GT lower not one was a bitch to remove.
Tue Sep 06, 2016 5:51 am
Soak it in PB Blaster for a day or two then beat that bitch some more
Tue Sep 06, 2016 6:36 pm
How much water in the LU grease warrants a seal change? I am not seeing any grease in the belt housing. I am noticing grease around the lower seal/prop; not a whole lot, but I have had raffia grass wrapped up in it and fishing line... I just pumped in new grease and 10 or so drops of water came out. I pump new grease in every 5-6 trips. Previously have seen a drop or two.
2010 GTR35 pushing an 1860 Gator-Tail Extreme
Mon Oct 31, 2016 2:39 pm
How about a link to both of these replacement parts.
That would be terrific.
Mon Oct 31, 2016 2:57 pm
Any water is bad. Replace the seal
Mon Oct 31, 2016 3:02 pm
Tue Nov 01, 2016 8:24 am
Lmao
Tue Nov 01, 2016 8:35 am
Changing prop shaft seals on my 17gtr how do you get the bearing out of the bearing cup thanks
1860 phowler extreme with a 37gtr
2072 sea ark 115 yamaha
Thu Oct 05, 2017 8:21 pm
