Mudbuddy pulley?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=64722
Author:  chevy01 [ Thu Nov 26, 2015 10:56 am ]
Post subject:  Mudbuddy pulley?
I have a stock 35 HD and did some mods. According to mudbuddys page they come stock with a 38/50 tooth pulley so I bought a 48t tore it down and seen it has a 36/47 tooth has any one ran into this and if I was to install the 48 I would gain bottom end correct?
Author:  deadbird8 [ Sat Nov 28, 2015 4:48 pm ]
Post subject:  Re: Mudbuddy pulley?
With the 36 tooth top you are pretty much stuck with one adjustment to lower the gear ratio- you can only go to a 46 tooth bottom which will move you to 1:28- the lowest you can go with what they have available that I know of. This will only drop your RPM about 2% going from a 47 to 46.
Most come with a 38 tooth clutch gear that allows a lot more adjustment (i.e. the 48 tooth would have got you to 1:26 and drop your RPM ~4%).
