It is currently Tue Jul 08, 2025 1:24 pm
Reply to topic  [ 11 posts ]
 Prop Advice---37GTR, 16.5x46 Instagator Hull
Post Prop Advice---37GTR, 16.5x46 Instagator Hull
Currently running a GT 11 pitch on one of Jay's 16.5x46 Instagator hulls.
Solo, it runs 31.7 with full fuel, battery, cooler, and a sack of 3 dozen decoys for a little added test weight--- normal load at 4250. Still runs over 30.5 solo with six dozen decoys, 35 Engel cooler, blind material (8 rolls of fastgrass), and all hunting gear.
2 guys/guns, one of the guys being 280lbs and same gear above,, it runs 28.5 at about 4100.
All in all the 11-pitch 3-blade runs great with the exception of some solid tiller torque when trimmed out and wide open unless the load is balanced just right. I generally cruise at 3600-3700 Rpms and 27-28mph. 11p gets me out of the hole pretty well too. I couldn't be more pleased with how the boat planes or runs or carries a load.
Problem is the three blade 11-pitch doesn't impress me much in really thick vegetation, particularly in reverse and I'm interested in a 2-blade but GT doesn't make an 11p two blade. I'm not familiar with GT's "new" 10.5 pitch which is supposedly made to compete with the Hammer from MB, or any of MB's props. Give me some suggestions. I don't need a big load carrying prop; my boat is .100 and pretty light. I just need a prop that will go through very heavy grass and reverses well in grass. No mud here in FL.
Tue Dec 01, 2015 10:07 pm
Post Re: Prop Advice---37GTR, 16.5x46 Instagator Hull
When i changed from the 3 blade to the 2 the performance in grass was much better IMO. I probably don't I have the "new" 2 blade your talking about but the "old" 2 blade was much better in grass if thats what your looking for.
Wed Dec 02, 2015 6:40 am
Get yourself a standard GT 2-blade.
It's a 10 pitch and is the best prop for running in vegetation and mud, and under a load.
Keep the 11P 3-blade for when youre running solo deepwater.
Thank me later.
Wed Dec 02, 2015 1:07 pm
Wed Dec 02, 2015 10:12 pm
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Dec 03, 2015 7:40 am
Thu Dec 03, 2015 2:43 pm
I could probably order one and get it polished locally. Do you really think it makes a difference?
Any opinions on the GT 2 blade compared to a Big Blade from Mudbuddy?
Fri Dec 04, 2015 7:09 am
A polished prop will be a little quicker.
The MB big blade is a little bigger than the GT 2-blade.
When I tested them side by side the GT prop was a little faster.
Fri Dec 04, 2015 2:25 pm
Tried the Big Blade today and was very impressed. Big and heavy. Should last longer than GT prop. Boat was just as fast as GT prop.
Gator tail
Sun Dec 06, 2015 11:56 am
I took my stock GT prop and Pitched it for a 12x10 to 12x11 and I gained on top end a lot.
Mon Dec 07, 2015 6:50 am
Finally found a new, "old style" GT 2-blade. Going to run it and see if I need to pitch it up a little bit, and polish/balance it.
Fri Dec 11, 2015 12:41 pm
Users browsing this forum: No registered users and 74 guests
