It is currently Mon Jul 07, 2025 10:41 am
[ 8 posts ] |
jasonphoto01
Joined: Wed Jan 28, 2009 10:41 pm Posts: 114 Location: Baton Rouge, LA
 Gatortail lowerunit
What exactly is the issue here? This isnt normal right?
Mon Mar 21, 2016 12:12 pm |
TPerkins
Joined: Wed Jan 02, 2013 12:59 pm Posts: 1793 Location: Clear Lake, Tx
 Re: Gatortail lowerunit
No picture
Mon Mar 21, 2016 12:42 pm |
jasonphoto01
Mon Mar 21, 2016 1:18 pm |
Russ
Yeah, not normal. Time to pull the shaft and see. Probably bearings, but could be the taper lock on the gear.
Mon Mar 21, 2016 1:26 pm |
jasonphoto01
Bearings were recently replaced so I'm guessing it's the taper lock. How hard is that to replace?
Mon Mar 21, 2016 2:28 pm |
jc
Not good I would pull it apart and check. There is a good post about replacing it, I'll see if I can find it.
Mon Mar 21, 2016 5:30 pm |
jc
Found it. HOTSAUCE170 Did a great write up on it.
Mon Mar 21, 2016 5:32 pm |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
This happened to someone else just two weeks ago. Should be an easy fix though
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
Mon Mar 21, 2016 5:50 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 46 guests |
