It is currently Fri Jul 04, 2025 9:36 pm
Reply to topic  [ 8 posts ]
 Gatortail lowerunit
Post Gatortail lowerunit
What exactly is the issue here? This isnt normal right?
Mon Mar 21, 2016 12:12 pm
Post Re: Gatortail lowerunit
No picture
Mon Mar 21, 2016 12:42 pm
Mon Mar 21, 2016 1:18 pm
Yeah, not normal. Time to pull the shaft and see. Probably bearings, but could be the taper lock on the gear.
Mon Mar 21, 2016 1:26 pm
Bearings were recently replaced so I'm guessing it's the taper lock. How hard is that to replace?
Mon Mar 21, 2016 2:28 pm
Not good I would pull it apart and check. There is a good post about replacing it, I'll see if I can find it.
Mon Mar 21, 2016 5:30 pm
Found it. HOTSAUCE170 Did a great write up on it.
Mon Mar 21, 2016 5:32 pm
This happened to someone else just two weeks ago. Should be an easy fix though
40HP Gatortail
Mon Mar 21, 2016 5:50 pm
Users browsing this forum: No registered users and 76 guests
