It is currently Mon Sep 22, 2025 12:47 pm
Reply to topic  [ 12 posts ]
 Slop behind the prop. (GTR lower shaft travel)
Post Slop behind the prop. (GTR lower shaft travel)
Is there supposed to be this much play in the shaft right behind prop?
Sun Dec 20, 2009 8:55 pm
Post Re: Slop behind the prop.
i dont own a gt but i would half to go with no on that one something cant be right
Sun Dec 20, 2009 9:01 pm
Profile YIM
No, your not supposed to have that!! Make sure your prop nut is tight!!
Sun Dec 20, 2009 9:02 pm
Sun Dec 20, 2009 9:04 pm
Profile YIM
The nut is tight... I can push and pull on the prop, it moves the whole shaft about 3/4 of an inch... Runs fine same speed and RPM's. I would think it would be that something came loose. I do notice a thud when i put it in gear might be shaft traveling.
Sun Dec 20, 2009 9:30 pm
Call Gator tail asap!
Sun Dec 20, 2009 9:39 pm
Mon Dec 21, 2009 9:42 am
Post Re: Slop behind the prop. (GTR lower shaft travel)
Went by GT this morning... Found that the washer behind the belt sprocket came off and the nut was pushing its way through...
Those guys dropped everything and got it fixed while I was there...
Great service
Mon Dec 21, 2009 10:16 am
You should have been at work...not worring about your duck boat...some coordinator you are.LOL :shock:
Mon Dec 21, 2009 9:00 pm
Mon Dec 21, 2009 9:05 pm
good to hear man
Mon Dec 21, 2009 9:09 pm
Profile YIM
1848 PD w/36 PD FPR
Tue Dec 22, 2009 6:27 pm
