Cracked Prop
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=67062
Author:  NegativeNed [ Thu Jun 02, 2016 4:13 pm ]
Post subject:  Cracked Prop
Doing my occasional inspection and repairs and discovered a hairline crack on the prop. Is this something I can send off and get repaired or will it only cause more damage in the future and just need to replace it?
Author:  scarygary [ Thu Jun 02, 2016 5:16 pm ]
Post subject:  Re: Cracked Prop
I had a 2 blade with a crack in the blade like that. I took a grinder and followed the crack then tig welded it up. It lasted another year, then threw the blade at 4800 rpm and in 3 seconds the vibration cracked the crank case cover and destroyed the clutch. If I had to do it again I'd throw it away
Author:  dead animal [ Thu Jun 02, 2016 7:49 pm ]
if you have never slung a blade off at wfo yet, get ready for some excitement!!!!!! lol
Author:  Richard in LA [ Fri Jun 03, 2016 4:40 am ]
I'd scrap it. The potential damage that a sling blade can inflict isn't worth what you may save. Out of curiosity, is that a 10 or 11 p prop? Can you post a pic of the other side?
Author:  msm8281 [ Fri Jun 03, 2016 5:43 am ]
Broken prop=broken LU especially if you have the new cast lower. Happened to me last weekend.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Author:  MaXXis85 [ Fri Jun 03, 2016 7:22 am ]
Please post a pic of the Engine side of the prop so I can see how the blades meet the hub
Author:  NegativeNed [ Sat Jun 04, 2016 4:35 am ]
Author:  HOTSAUCE170 [ Sat Jun 04, 2016 6:16 am ]
send it to gatortail before you scrap it they will probably help you out on a new prop. it never hurts to ask.
Author:  rubbinisracin [ Sun Jun 05, 2016 6:42 pm ]
What number is stamped into that prop?
Author:  NegativeNed [ Tue Jun 07, 2016 7:39 am ]
Author:  rubbinisracin [ Tue Jun 07, 2016 7:47 am ]
Oh ok thanks.
Author:  brstanle [ Tue Jun 07, 2016 2:55 pm ]
I'd cut that bastard in half and junk it. Baaaaaaad situation waiting to happen, lucky you caught it!
Author:  NegativeNed [ Thu Jun 09, 2016 6:58 am ]
