It is currently Mon Sep 22, 2025 1:21 pm
Reply to topic  [ 13 posts ]
 Cracked Prop
Post Cracked Prop
Doing my occasional inspection and repairs and discovered a hairline crack on the prop. Is this something I can send off and get repaired or will it only cause more damage in the future and just need to replace it?
1754 Gatortrax / GTR 37 EFI
Thu Jun 02, 2016 4:13 pm
Post Re: Cracked Prop
I had a 2 blade with a crack in the blade like that. I took a grinder and followed the crack then tig welded it up. It lasted another year, then threw the blade at 4800 rpm and in 3 seconds the vibration cracked the crank case cover and destroyed the clutch. If I had to do it again I'd throw it away
Thu Jun 02, 2016 5:16 pm
if you have never slung a blade off at wfo yet, get ready for some excitement!!!!!! lol
Thu Jun 02, 2016 7:49 pm
I'd scrap it. The potential damage that a sling blade can inflict isn't worth what you may save. Out of curiosity, is that a 10 or 11 p prop? Can you post a pic of the other side?
GTR, Waitin' on a DFOU hull
Fri Jun 03, 2016 4:40 am
Broken prop=broken LU especially if you have the new cast lower. Happened to me last weekend.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Fri Jun 03, 2016 5:43 am
Please post a pic of the Engine side of the prop so I can see how the blades meet the hub
Fri Jun 03, 2016 7:22 am
Sat Jun 04, 2016 4:35 am
send it to gatortail before you scrap it they will probably help you out on a new prop. it never hurts to ask.
Sat Jun 04, 2016 6:16 am
What number is stamped into that prop?
1854 CC backyard build with GTR 37 EFI
Build thread here.. viewtopic.php?f=4&t=66815
Sun Jun 05, 2016 6:42 pm
Tue Jun 07, 2016 7:39 am
Oh ok thanks.
Tue Jun 07, 2016 7:47 am
I'd cut that bastard in half and junk it. Baaaaaaad situation waiting to happen, lucky you caught it!
Tue Jun 07, 2016 2:55 pm
Thu Jun 09, 2016 6:58 am
