Gen 3 or 4 PD lower unit? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=67401 |
Author: | NaturalLightKid [ Tue Jul 05, 2016 7:27 am ] |
Post subject: | Gen 3 or 4 PD lower unit? |
How can you tell if a PD has a gen 3 or 4 lower unit? What are thw gear ratio for both? |
Author: | wade_660 [ Tue Jul 05, 2016 7:33 am ] |
Gen 3 is a 2:1 ratio Gen 4 is a 1.52:1 ratio I could be wrong but I think the 4 has a hex shaft and the 3 does not. Sent from my iPhone using Tapatalk |
Author: | BlueShamu [ Tue Jul 05, 2016 8:11 am ] |
There are no Gen 4's. Only Gen 3's with two different gearing options....noted above. |
Author: | NaturalLightKid [ Tue Jul 05, 2016 8:34 am ] |
Post subject: | Re: Gen 3 or 4 PD lower unit? |
Author: | BlueShamu [ Tue Jul 05, 2016 11:38 am ] |
Prodrive can probably tell you....or tell us what speeds your getting on what size rig....the majority will figure it out real quick. |
Author: | JphIII [ Tue Jul 05, 2016 11:41 am ] |
There is a way to tell, apparently there is some kind of marking on the L/U. I can't remember what it is though... |
Author: | wade_660 [ Tue Jul 05, 2016 11:51 am ] |
I saw one this weekend. It'll be right under the gear box on the lower unit on the oil filter side. I swore it said gen 4. Could be wrong. Would the hex shaft not give it away, or does a gen 3 have a hex? Sent from my iPhone using Tapatalk |
Author: | BlueShamu [ Tue Jul 05, 2016 12:38 pm ] |
Did PD go from splined to hex? Sent from my iPhone using Tapatalk |
Author: | BlueShamu [ Tue Jul 05, 2016 12:45 pm ] |
Author: | teammarshmafia [ Tue Jul 05, 2016 4:22 pm ] |
They have a tapered splined shaft not a hex Sent from my SAMSUNG-SM-G890A using Tapatalk |
Author: | wade_660 [ Tue Jul 05, 2016 4:44 pm ] |
I stand corrected. Carry on Sent from my iPhone using Tapatalk |
Author: | NaturalLightKid [ Tue Jul 05, 2016 6:07 pm ] |
Author: | cb5331 [ Tue Jul 05, 2016 6:10 pm ] |
Uh oh. Blue, what you think that g4 stamp stands for? ![]() |
Author: | Russ [ Tue Jul 05, 2016 6:15 pm ] |
It's stands for "Blue is getting his lower unit yanked by pd" ![]() |
Author: | BlueShamu [ Tue Jul 05, 2016 7:45 pm ] |
I stand corrected, then. PD needs to update their manuals! Sent from my iPhone using Tapatalk |
Author: | NaturalLightKid [ Wed Jul 06, 2016 5:24 pm ] |
How much cost/trouble is it to convert one from a 3 to a 4? |
Author: | cb5331 [ Wed Jul 06, 2016 5:50 pm ] |
If you got a way to suspend the engine for a few minutes (preferably an engine hoist), its pretty easy. Maybe a 30 minute job. Lil more the first time you do it, lil less if you've done it before. |
Author: | cupnglide [ Thu Jul 07, 2016 8:53 am ] |
Last time I checked on cost, it was $1500 for the part. That was back when they introduced the 1.52:1 part. |
Author: | NaturalLightKid [ Fri Jul 08, 2016 11:55 am ] |
