About to Get Outside the Box http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=68082 |
Author: | BlueShamu [ Wed Aug 31, 2016 11:36 am ] |
Post subject: | About to Get Outside the Box |
Stay tuned.... |
Author: | flint87 [ Wed Aug 31, 2016 12:02 pm ] |
Post subject: | Re: About to Get Outside the Box |
Author: | brickgw [ Wed Aug 31, 2016 12:17 pm ] |
Subscribed....i got 2 of them laying in the garage that are worn out and running the stock 2 blade. Curious to see what's going on here lol |
Author: | BlueShamu [ Wed Aug 31, 2016 12:23 pm ] |
Prop on the left....13" diameter splined Gen III hub. Prop on the right....11" threaded/tapered bushing Gen II hub. Going to attempt to make the Gen III fit a Gen II. From there...I have plenty of prop to work with on another design altogether....contemplating ultimately ending up with a 3 blade Cleaver with maybe a 12" diameter. Ultimately, probably a costly experiment. |
Author: | teammarshmafia [ Wed Aug 31, 2016 12:26 pm ] |
I'm gonna go out on a limb here and say blue is gonna try that gen 3 prop on his gen2. And the smaller one looks like a gdsd 3 blade. I forsee some rebroaching fixina happen Sent from my SAMSUNG-SM-G890A using Tapatalk |
Author: | banded-mallard [ Wed Aug 31, 2016 12:46 pm ] |
Troy, I haven't pulled mine before, but is it possible to take a gen 3 lower, remove the shaft and gear and swap it to a gen 2 lower? Thus keeping the splined shaft. The gearing would be different. But the second question would be could the bevel gear be removed from one and placed on the other? Thus giving you a gen 2 lower with a splined shaft rather than a threaded shaft. |
Author: | banded-mallard [ Wed Aug 31, 2016 12:47 pm ] |
Because if that is possible, I would love to see a 3 blade 13" run on my Kawi with all that torque. Hell I'm running a 14P now at 4900-4950 |
Author: | BlueShamu [ Wed Aug 31, 2016 2:18 pm ] |
I don't know if the shaft diameters/length are the same throughout the length of the shaft and where they press into the gears. I screwed up and eventually threw my sheared shaft away. Wish I would have kept it in hindsight. I would give it to a machine shop and tell them make me one with hex flats on the end so I could play with and change out MB and GT props. I think the beveled gears and bearings are press fit. |
Author: | BlueShamu [ Wed Aug 31, 2016 2:19 pm ] |
I've even given thought to weld overlay my threads and machine hex flats onto it....but, that would probably turn out bad. LOL I'll just add.....threaded props are the devil! |
Author: | SETx Longtail [ Wed Aug 31, 2016 4:42 pm ] |
I'm all in on this one. Very interested in what you come up with. Hhmmmm, that splined 13p prop with some 7/8" threads... Oh the possibilities! |
Author: | banded-mallard [ Wed Aug 31, 2016 4:43 pm ] |
I thought GTR and MB are a different rotation pitch |
Author: | SETx Longtail [ Wed Aug 31, 2016 4:47 pm ] |
I was under the impression all these lawnmower boat motor mud prop things turned the same direction. |
Author: | banded-mallard [ Wed Aug 31, 2016 4:59 pm ] |
They prob do, but don't know for sure. |
Author: | Quackhead62 [ Wed Aug 31, 2016 5:09 pm ] |
I like the way you are thinking Blue that would open up lots of things for the guy with the gen II threaded shafts. I'm going to stay tuned for sure. Sent from my iPhone using Tapatalk |
Author: | cb5331 [ Wed Aug 31, 2016 5:23 pm ] |
Nm, didnt read whole thread |
Author: | Will [ Wed Aug 31, 2016 5:54 pm ] |
There's an old Evinrude left hand prop that's the same spline. Still don't know why someone hasn't tried one for running open water |
Author: | banded-mallard [ Thu Sep 01, 2016 4:19 am ] |
I'm still wondering if someone has tried to remove the gear off the shaft yet. Zimmer gear here in Baton Rouge prob has em or can get em. This would allow for ratio changes as well as prop changes. |
Author: | BlueShamu [ Thu Sep 01, 2016 3:06 pm ] |
I think I know why PD went 2:1 instead of something inbetween...your motor needs some gearing or some huevos to turn an additional 2 pounds of weight! |
Author: | Quackhead62 [ Thu Sep 01, 2016 6:06 pm ] |
Author: | cupnglide [ Thu Sep 01, 2016 7:26 pm ] |
Wow. I knew there had to be a difference. Didn't expect it to be that much. |
Author: | BlueShamu [ Thu Sep 01, 2016 8:31 pm ] |
Author: | TPerkins [ Fri Sep 02, 2016 8:48 am ] |
I wonder how much weight difference there is between a power tech vs big blade vs hammer. Sent from my SM-G920V using Tapatalk |
Author: | BlueShamu [ Sat Sep 10, 2016 5:35 pm ] |
Ran a few beads over the splines using SMAW and 316L filler. Ran wide weave beads starting as far as I could get the rod into the opening and worked the rod out. Ran a pass around the circumference of the opening, over the ends of each pass to clean it up and get above the back side. Next up...drill, tap and machine. |
Author: | SETx Longtail [ Sat Sep 10, 2016 5:41 pm ] |
Need to do another one and drill it for 7/8..... Just sayin. ![]() |
Author: | flint87 [ Sat Sep 10, 2016 8:06 pm ] |
Author: | BlueShamu [ Sat Sep 10, 2016 8:12 pm ] |
Author: | banded-mallard [ Tue Oct 04, 2016 12:03 pm ] |
Well, did the welds hold? ![]() |
Author: | BlueShamu [ Fri Oct 07, 2016 9:38 pm ] |
Been too dang busy on y'all's WKM's to do ANYTHING! Hope to have them finished, tomorrow. |
Author: | banded-mallard [ Tue Oct 11, 2016 5:10 am ] |
Author: | BlueShamu [ Wed Oct 12, 2016 8:06 pm ] |
We shipping our six WKM's in the morning. But, we picked up a couple Delta BF's and a knife gate....you guys shouldn't wait ten years to work these things! LOL |
