It is currently Thu Jul 03, 2025 5:00 pm
Reply to topic  [ 30 posts ]
 Stuck prop, help
Post Stuck prop, help
14HP mudbuddy. Decided to replace this crappy prop. Barely pushes me unless I trim all the way and can barely get 10mph with a 1648 alumacraft not loaded. Prop measures 9.5inches.
Supposed to be 10. And it's all around sharp and jagged.
I got the nut off but now the devil of a prop is stuck. It's a threaded shaft
Searched all over trying to find answers got some vague answers. Can anyone be specific or give me an idea.
Mon Sep 05, 2016 11:28 am
Post Re: Stuck prop, help
Piece of flatbar with a hole in one end that slips over the shaft. Needs to be 3ft or so for leverage. Use that to break it loose.
Mon Sep 05, 2016 12:08 pm
Mon Sep 05, 2016 12:14 pm
If you have a short piece of 2x4 handy you can drill a hole in one end and probably make that work also
1854 Prodigy DPE Level 3 HDR
Mon Sep 05, 2016 12:17 pm
Mon Sep 05, 2016 12:18 pm
I'll add that when trying to turn prop. The whole shaft spins with prop.
Mon Sep 05, 2016 12:25 pm
You may have to take the outdrive off and hold it from the other end somehow. I'm not completely sure as I have a hex shaft. Google search mud buddy threaded shaft prop removal. I'm sure there has been a thread on this before. Go ahead and put the penetrating fluid to it now.
Mon Sep 05, 2016 12:29 pm
Mon Sep 05, 2016 12:31 pm
Chances are you're going to need to get the outdrive off. Find a way maybe to secure the pulley enough to break the prop. If you use heat you'll probably have to replace seals then.
Mon Sep 05, 2016 12:39 pm
Mon Sep 05, 2016 12:43 pm
viewtopic.php?t=50418
Mon Sep 05, 2016 2:28 pm
viewtopic.php?t=44986
Mon Sep 05, 2016 2:32 pm
What you gotta do is hold your prop wrench on the prop. Have a buddy crank the motor as you hold the prop wrench and the power of the motor will spin that sucker right off.
Mon Sep 05, 2016 2:56 pm
That has major fail written all over it. I suggest not trying that lmao
Mon Sep 05, 2016 2:59 pm
Haha. Yeah I'm totally gonna do this hold my beer. I do not want to cut. Might just end up removing shaft. Idk.
GOTTA' KILL EM' TO GRILL EM'
Mon Sep 05, 2016 3:04 pm
Mon Sep 05, 2016 7:31 pm
Is the prop supposed to be right up on the bearing/bushing housing cap like that? Looks like its jammed on the cap to me. That'll slow you down.
1438 Jon / 23hp MBLT
Tue Sep 06, 2016 11:19 am
Tue Sep 06, 2016 12:17 pm
Wed Sep 07, 2016 6:03 am
Wed Sep 07, 2016 9:11 am
Wed Sep 07, 2016 9:42 am
Wed Oct 05, 2016 8:37 pm
Found shallow water to. Motor doesn't do me no good at all as it sits right now.
Trying to go through less than a foot of water it bogs down then bites and pushes forward and then looses bite. And repeats. And repeats..
Wed Oct 05, 2016 8:41 pm
My 2.5 cents! Back in the day when I ran a GDLT had the same problem. Worked at for 2-3 hours, finally after totally giving up, I start the engine and rev it up and down for about 3 minutes then damnit if it didn't spin right off when I killed it! Might be worth the try?
Thu Oct 06, 2016 7:45 am
Thu Oct 06, 2016 2:21 pm
With the board or flat bar in place, smack it with a maul or heavy hammer real hard. Try to work it like an impact wrench.
Thu Oct 06, 2016 2:30 pm
UPDATE.
prop and shaft housing are straight. just a weird picture. still stuck.
Fri Oct 07, 2016 12:15 pm
Just cut it with a cutting wheel and stop just short of the threads, then drive a cold chisel in the cut. Will come right off after that.
Fri Oct 07, 2016 3:18 pm
SO What happened? Off/on cut/hammered?
Tue Oct 11, 2016 10:38 am
Tue Oct 11, 2016 6:21 pm
Users browsing this forum: No registered users and 70 guests
