Stuck prop, help http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=68151 |
Author: | quentinp35 [ Mon Sep 05, 2016 11:28 am ] |
Post subject: | Stuck prop, help |
14HP mudbuddy. Decided to replace this crappy prop. Barely pushes me unless I trim all the way and can barely get 10mph with a 1648 alumacraft not loaded. Prop measures 9.5inches. Supposed to be 10. And it's all around sharp and jagged. I got the nut off but now the devil of a prop is stuck. It's a threaded shaft Searched all over trying to find answers got some vague answers. Can anyone be specific or give me an idea. |
Author: | Russ [ Mon Sep 05, 2016 12:08 pm ] |
Post subject: | Re: Stuck prop, help |
Piece of flatbar with a hole in one end that slips over the shaft. Needs to be 3ft or so for leverage. Use that to break it loose. |
Author: | quentinp35 [ Mon Sep 05, 2016 12:14 pm ] |
Author: | JD145 [ Mon Sep 05, 2016 12:17 pm ] |
If you have a short piece of 2x4 handy you can drill a hole in one end and probably make that work also |
Author: | quentinp35 [ Mon Sep 05, 2016 12:18 pm ] |
Author: | quentinp35 [ Mon Sep 05, 2016 12:25 pm ] |
I'll add that when trying to turn prop. The whole shaft spins with prop. Sent from my iPhone using Tapatalk |
Author: | JD145 [ Mon Sep 05, 2016 12:29 pm ] |
You may have to take the outdrive off and hold it from the other end somehow. I'm not completely sure as I have a hex shaft. Google search mud buddy threaded shaft prop removal. I'm sure there has been a thread on this before. Go ahead and put the penetrating fluid to it now. |
Author: | quentinp35 [ Mon Sep 05, 2016 12:31 pm ] |
Author: | JD145 [ Mon Sep 05, 2016 12:39 pm ] |
Chances are you're going to need to get the outdrive off. Find a way maybe to secure the pulley enough to break the prop. If you use heat you'll probably have to replace seals then. |
Author: | quentinp35 [ Mon Sep 05, 2016 12:43 pm ] |
Author: | lastchance [ Mon Sep 05, 2016 2:28 pm ] |
viewtopic.php?t=50418 |
Author: | lastchance [ Mon Sep 05, 2016 2:32 pm ] |
viewtopic.php?t=44986 |
Author: | flint87 [ Mon Sep 05, 2016 2:56 pm ] |
What you gotta do is hold your prop wrench on the prop. Have a buddy crank the motor as you hold the prop wrench and the power of the motor will spin that sucker right off. Sent from my iPhone using Tapatalk |
Author: | Russ [ Mon Sep 05, 2016 2:59 pm ] |
That has major fail written all over it. I suggest not trying that lmao |
Author: | quentinp35 [ Mon Sep 05, 2016 3:04 pm ] |
Haha. Yeah I'm totally gonna do this hold my beer. I do not want to cut. Might just end up removing shaft. Idk. GOTTA' KILL EM' TO GRILL EM' |
Author: | flint87 [ Mon Sep 05, 2016 7:31 pm ] |
Author: | nuccifish06 [ Tue Sep 06, 2016 11:19 am ] |
Is the prop supposed to be right up on the bearing/bushing housing cap like that? Looks like its jammed on the cap to me. That'll slow you down. |
Author: | flint87 [ Tue Sep 06, 2016 12:17 pm ] |
Author: | nuccifish06 [ Wed Sep 07, 2016 6:03 am ] |
Author: | flint87 [ Wed Sep 07, 2016 9:11 am ] |
Author: | JD145 [ Wed Sep 07, 2016 9:42 am ] |
Author: | quentinp35 [ Wed Oct 05, 2016 8:37 pm ] |
Author: | quentinp35 [ Wed Oct 05, 2016 8:41 pm ] |
Found shallow water to. Motor doesn't do me no good at all as it sits right now. Trying to go through less than a foot of water it bogs down then bites and pushes forward and then looses bite. And repeats. And repeats.. Sent from my iPhone using Tapatalk |
Author: | CypressCritter [ Thu Oct 06, 2016 7:45 am ] |
My 2.5 cents! Back in the day when I ran a GDLT had the same problem. Worked at for 2-3 hours, finally after totally giving up, I start the engine and rev it up and down for about 3 minutes then damnit if it didn't spin right off when I killed it! Might be worth the try? |
Author: | quentinp35 [ Thu Oct 06, 2016 2:21 pm ] |
Author: | reharbert [ Thu Oct 06, 2016 2:30 pm ] |
With the board or flat bar in place, smack it with a maul or heavy hammer real hard. Try to work it like an impact wrench. |
Author: | quentinp35 [ Fri Oct 07, 2016 12:15 pm ] |
UPDATE. prop and shaft housing are straight. just a weird picture. still stuck. |
Author: | Goose Crumpler [ Fri Oct 07, 2016 3:18 pm ] |
Just cut it with a cutting wheel and stop just short of the threads, then drive a cold chisel in the cut. Will come right off after that. |
Author: | CypressCritter [ Tue Oct 11, 2016 10:38 am ] |
SO What happened? Off/on cut/hammered? |
Author: | quentinp35 [ Tue Oct 11, 2016 6:21 pm ] |
