It is currently Mon Sep 22, 2025 3:58 pm
Reply to topic  [ 9 posts ]
 Loose skeg on a new motor
Post Loose skeg on a new motor
My skeg is pretty loose I can move it up and down about 1/4" and side to side 1/4+" each way. I have less than 20 hr on it. I can tighten the bolts no problem but should I try and claim this on warranty just incase the holes on the skeg got a little egg shaped from it being lose?
Fri Sep 16, 2016 7:34 pm
Post Re: Loose skeg on a new motor
Which motor?
Fri Sep 16, 2016 9:34 pm
37HDR
Sat Sep 17, 2016 3:56 am
Tighten the skeg!
Refurbishing a Prodrive
Sun Sep 18, 2016 8:11 am
Nothing to claim (IMHO).
Things come loose on my rig all the time.
Mud motor maintenance 101.....Use the proper loctite on the bolts/ nuts, tighten it up, and check them after every trip out.
Sun Sep 18, 2016 8:44 am
The skeg is welded to the outdrive. You talking about the support brace on top maybe?
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Sun Sep 18, 2016 9:27 am
The hdr skeg is bolted on the cav plate is welded on the hdr. The hd skeg is welded, just tighten the bolts.
Sun Sep 18, 2016 1:34 pm
I tightend the bolts. Got about 1-1.5 rounds out of them which is a lot. I was more worried the holes would get slightly egg shaped and case tightening issues down the road. I didn't use lock tight but I will if/when they come loose again
Mon Sep 19, 2016 12:52 pm
Its just a regular nut or a nylock?
Mon Sep 19, 2016 1:26 pm
