Another prop test... http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=68384 |
Author: | tnfrainier [ Sat Sep 24, 2016 3:27 pm ] |
Post subject: | Another prop test... |
Tested three different props today... Boat Prodigy 1860 elite 24" sides Hunt deck 8" cat walks Blind 37 efi gator tail Barracuda 5 Load Dog ~85lbs Me ~275 Cooler+Misc ~150lbs All speeds were done with speed tracker on my phone I rarely push the motor to these RPM's but I wanted to see what these props would do. Today's testing - Deep water light chop 10P Stock three blade 29.4 - 30.4 4600 RPM Reverse is OK at best GTR 2 Blade new, worked by Baggy 29.6 - 30.3 4375 RPM Reverse is much improved Had a strange harmonic when cruising at ~ 3400 RPM 11P 3 Blade one season old just reworked by Baggy 32.1 - 32.4 MPH 4700+ still pulling when it hit the limiter Reverse is about the same as the two blade, but I think the two blade is better. Very smooth no harmonics at any RPM These test were done last year with about the same load: Before Barracude modification - deep water 10P Stock three blade 25.5 - 26.5 mph 4150 to 4350 rpm Touched 26.9 once After modification - deep water 10P Stock three blade 29.5 - 30.2 4400+ rpm Conclusion, Baggy does great work! He did both props in less than a week and his work looks and performs great. The stock three blade didn't have much wear but one of the blades took a small hit and was slightly misaligned, after he was finished it looked brand new. This was the first time I had sent him any work, I will be a repeat customer. |
Author: | BlueShamu [ Sat Sep 24, 2016 4:33 pm ] |
Post subject: | Re: Another prop test... |
What's the diameter between the 10" and 11" pitch 3 blades? The 11" would have to be smaller diameter to turn more RPM's....just my thoughts. |
Author: | Russ [ Sat Sep 24, 2016 5:04 pm ] |
Not necessarily, blue. How the pitch is done, amount of cup, amount of rake, how that spot near the hub is done, etc. Lots of factors. May very well be same diameter. |
Author: | tnfrainier [ Sat Sep 24, 2016 5:23 pm ] |
The 10P prop measures 11 1/2" and the 11P reworked prop measures 11". I did not measure the 11P prop prior to sending it out. |
Author: | BlueShamu [ Mon Sep 26, 2016 8:49 pm ] |
