It is currently Fri Jul 04, 2025 10:22 am
Reply to topic  [ 17 posts ]
 Has anyone upgraded their PD lower from a gen 2
Post Has anyone upgraded their PD lower from a gen 2
Has anyone upgraded their PD lower from a gen 2 to a gen 3 or other? And if so do you have the old lower lying around.
Thu Sep 01, 2016 4:31 am
Post Re: Has anyone upgraded their PD lower from a gen 2
I like where you're going with this...
I'll add....does anybody that has ever sheared their Gen II shaft and replaced it in kind still have the sheared shaft/gears laying around they would be willing to part with?
Thu Sep 01, 2016 7:07 am
Ha, I had a sheared gen 2 with gear and gen 3 with gear, but they're in a landfill somewhere now...
Sent from my XT1254 using Tapatalk
Thu Sep 01, 2016 8:48 am
Thu Sep 01, 2016 9:10 am
I have a sheared gen 2 shaft. Have been planning to get a duplicate machined but never have. It's broken right where the threads start. Gears and bearings are fine
Thu Sep 01, 2016 9:23 am
Then you could actually do it. have the shaft spec'd and see if you can remove the gear. Put the shaft and gear in the freezer. Then heat up the gear (lightly) with a torch and if its a press fit, it should come free. Could get another shaft built to run different props.
Thu Sep 01, 2016 9:27 am
I have a 20 ton hydraulic press...
Thu Sep 01, 2016 9:57 am
I have a gen 2. skeg is loose, other than that it's perfect. the prop has low hours.
not for sale or trade, btw. I keep it for a backup.
Thu Sep 01, 2016 10:15 am
I may have an unbroken shaft that was worn, gear still in tact. Shoot me a text this evening sometime and I'll see if I still have it.
I also have a whole LU, but I think it's a gen1, and it still works, just had the never ending seal issue so not real interested in butchering it.
Thu Sep 01, 2016 10:21 am
Ok. I have a close friend who has a machine shop and depending if the gear can be removed, I could have a shaft made to run just about any prop.
Thu Sep 01, 2016 11:12 am
Just remind me. I'll send it to you if I have it. Pretty sure it's sitting on my deep freeze in the garage.
Thu Sep 01, 2016 11:19 am
ok
Thu Sep 01, 2016 11:43 am
Send me a PM. I might be able to get you a broken shaft
I gave up mud motors
Thu Sep 01, 2016 3:39 pm
Thu Sep 01, 2016 3:47 pm
Fri Sep 02, 2016 7:22 am
I've got a gen 3 that I sheared Saturday. Running in the middle of the canal and all of a sudden, the motor hit the rev limiter and I caught a split second view of the prop and shaft before it sunk.
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Mon Oct 10, 2016 9:01 am
2014 Pro Drive Gen 3
2014 17x54 X-Series
Mon Oct 10, 2016 1:20 pm
Users browsing this forum: No registered users and 49 guests
