It is currently Thu Jul 03, 2025 4:49 pm
[ 7 posts ] |
Gros'bec
Joined: Sat Jul 23, 2011 11:36 am Posts: 235 Location: Louisiana
 BELT TENSION QUESTION
BELT TENSION QUESTION: I put a new belt on and tensioned it to 20lbs since that's the requirement on Mudbuddy motors. I ran it on the water for for about 20 mins. Now the belt has stretched a little and tension is at 15 lbs. The question is, do I now just retention it to 16lbs and keep it there or should I go a little tighter since it's still new?
_________________ 18x44 Gator Trax, Stage 2 Mudbuddy
Sun Oct 23, 2016 1:00 pm |
Russ
 Re: BELT TENSION QUESTION
Run it. When it drops below 13, tighten it to 16, check it for a couple hours, then you should be good to go.
Sun Oct 23, 2016 5:17 pm |
Gros'bec
Got it Russ thanks.
One more question. I put a new clutch on and used red Loctite and torque the clutch bolt to 55 foot lbs. Is that good or should I go a little less? I saw gator Trax video where they recommended 55 foot pounds, but also saw some specs on here where someone said 50 ft pounds. It's a 2006 Mudbuddy. Not the new HDR model
Sun Oct 23, 2016 6:55 pm |
Russ
55.
Sun Oct 23, 2016 9:44 pm |
Gros'bec
Roger that
Sun Oct 23, 2016 10:27 pm |
Namasuke
Learn to follow
Mon Oct 24, 2016 5:16 am |
Gros'bec
Mon Oct 24, 2016 4:00 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 68 guests |
