It is currently Tue Sep 23, 2025 12:46 pm
[ 4 posts ] |
riverratdm84
Joined: Fri Jul 30, 2010 3:15 pm Posts: 701 Location: pella, ia
 Cracked mb outdrive
Seen my outdrive was cracked around the tube so I figured I better regrease it. I pulled the relief screw and it was broke off half way down. So I drilled out what was left in there and got it greased. Do you think I dare run it the rest of the season like this. I don't want to be without a boat. Also has anyone tried welding this with success? I'm sure MB will want to sell me a new outdrive.
Tue Nov 15, 2016 5:30 pm |
cb5331
 Re: Cracked mb outdrive
Weld it up. They crack there a lot.
Tue Nov 15, 2016 5:45 pm |
Andy
Joined: Tue Oct 27, 2015 9:44 pm Posts: 278 Location: Coral Springs, FL
You'll be fine. Just make sure it doesn't crack all the way around. I have a spare outdrive I'll sell you for the low if you want. It's a 27"
_________________ Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF -Unbaffled VooDoo -Gator Glide G2 with base -Wet Sounds Stealth 10 Ultra V2 -Green LED Courtesy Lights -15" Combo LED Light Bar
Tue Nov 15, 2016 6:09 pm |
riverratdm84
Thanks guys. I'm gonna weld it and see how that holds. Andy, I'll definitely keep that spare in mind if I wind up needing one.
Tue Nov 15, 2016 8:43 pm |
[ 4 posts ] |
