It is currently Mon Sep 22, 2025 4:03 am
[ 8 posts ] |
rotten_1
Joined: Mon Aug 26, 2013 3:01 pm Posts: 21 Location: Wichita, KS
 Shop Built SD (Kind of)
I have known for a while my budget (wife) would not allow a SD to be purchased new so I have decided to build one with the help of a MB lower I picked up a year ago.
Here is my progress for now, still trying for figure it out, but I'm coming along.
Started with the 27" MB lower I picked up from a user here.
After looking for a housing or a 8"x2" rectangle tub with no luck, I decided to weld one up. I'm not a welder so all the seams will need to be ground and smoothed.
After a search on McMaster & Carr I found the timingbelt and gears for the MB lower and from Harbor Freight a new predator motor.
I just started on the transom mount (again building from scratch, and welds are definitely not pro quailty.)
I should be able to start bolting everything together this week to see about fitment and alignment as most all the parts are here.
_________________ Minimum wage jobs are for minimum experienced people.
Sat Nov 19, 2016 6:28 pm |
Gunshinestate407
Joined: Tue Dec 23, 2014 1:58 pm Posts: 216 Location: Orlando
 Re: Shop Built SD (Kind of)
I have a mounting plate for the power head (small block) off a MudBuddy HD that I can part with. Let me know if u need it
Sat Nov 19, 2016 7:08 pm |
Buckmark311
interested to see how this bad boy turns out.
Mon Nov 21, 2016 2:24 pm |
rotten_1
I got the Motion Base mocked up and aligned.
Now I'm waiting on the darn Woodruff Key forthe lower gear. Having issues finding a metric key.
Mon Nov 21, 2016 4:37 pm |
Westi
Joined: Fri May 29, 2009 2:53 pm Posts: 1006 Location: TEXAS
I'm gonna go ahead and follow this. Good luck.
Tue Nov 22, 2016 5:13 pm |
rotten_1
I ran into my first major design snag.
Maybe I have not noticed it in other engines, but the mounting plate is off center to the shaft of the motor by about 3/4".
This doesnt make a large difference in the overall idea I have in my brain, but definatly frusterating it didn't initially work as expected for further progress last night.
Wed Nov 23, 2016 9:07 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
Is that steel your making the frame out of? That's going be 1 heavy bitch!
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Wed Nov 23, 2016 11:33 am |
SETx Longtail
The GoDevil Surface Drive frame, transom mount, and outdrive are 100% plate steel, and no heavier than the competition. This one will be just fine.
_________________ #CFFITR
Fri Nov 25, 2016 4:06 pm |
[ 8 posts ] |
