Gator Tail lower seals
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=69176
Author:  Ricerunner [ Wed Dec 07, 2016 1:42 am ]
Post subject:  Gator Tail lower seals
Has anyone done any research as to a different supplier for the lower unit (prop end) seals. Seems like $150 for a couple of seals is a bit steep. I had to order some and when they get here I'll be doing some checking through my parts planner at the plant to see if he can find a replacement out there for substantially less. I figure someone else has gone this route and I'm not finding it in the search mode.
Author:  duck_watcher12 [ Wed Dec 07, 2016 10:06 am ]
Post subject:  Re: Gator Tail lower seals
You have the new style lower?
Author:  txmudcutter [ Wed Dec 07, 2016 2:30 pm ]
Here ya go this might help
viewtopic.php?f=41&t=64341
Author:  MaXXis85 [ Wed Dec 07, 2016 3:06 pm ]
$125 for a full rebuild kit on an extruded unit. Id have to check the Cast kit.
Author:  Ricerunner [ Wed Dec 07, 2016 5:11 pm ]
Yeah I have the new cast lower
Author:  duck_watcher12 [ Wed Dec 07, 2016 6:11 pm ]
Find a single lip seal that's 1.125 id. 1.5 od and a width of .190 or a double lip seal that 1.125 I'd 1.5 od .25 width for the rear seal at the prop and I'm sure you have the other part numbers. Any local industrial supplier of bearings should have or be able to get everything at a reasonable cost. If you need a part number on anything let me know
Author:  Ricerunner [ Sun Dec 11, 2016 3:30 am ]
Well I was mistaken the entire LU rebuild kit was 135
Author:  coltonkallie25 [ Sun Dec 11, 2016 10:40 am ]
Does anyone know how I can tell if my lower seal is busted on my gtr37efi 5 or 8 or so drops comes out when I pump grease too it but never just comes out when I open the purge screw it's bugging the crap out of me how can I tell if the seal is busted
Author:  SETx Longtail [ Sun Dec 11, 2016 10:42 am ]
Just keep pumping with the purge screw in, when you see grease, it's busted. Install new seals and repeat!!
Author:  rubbinisracin [ Tue Dec 13, 2016 8:10 am ]
Mine pushes out water every time I re grease it, the water is always clear. Has done this since new. I may bump my interval to every 10 hours on the lower one. Also I'm not sure where the grease is going, takes a few pumps to get grease to come out so I know its losing it, just don't know if it's losing it to the inside or outside...I don't ever see grease coming out on the prop, so I'm guessing to the inside...
Author:  MaXXis85 [ Tue Dec 13, 2016 11:07 am ]
The seals are designed to push excess out the back if installed correctly. as grease gets hot it expands and will expel a small amount each time of use. As it cools the water can be pulled into the shaft housing. Keep up with maintenance, is all you can do and replace the seals and wear sleeve at the time you wish.
