It is currently Mon Sep 22, 2025 5:58 am
Reply to topic  [ 4 posts ]
 No trim or reverse
Post No trim or reverse
I think I know what the issue is but wanted to see if anyone else had anything else I should check before digging to far into the problem.
I have a gen III prodrive when I hit the trim or the reverse switch all I get is a click at the relay under the cover by the pump I'm assuming the relay has gone bad. But wanted some other opinions before I get to far scratching my head chasing electrical demons. Thanks
Dont criticize a farmer with your mouth full
Sat Dec 10, 2016 11:14 am
Mon Dec 12, 2016 1:10 pm
Post Re: No trim or reverse
Also check your connections on the solenoid. Loosen em up, make sure they are clean, apply some electrical grease, and retighten. I run mine in saltwater regularly and have to do this at least once a year.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Mon Dec 12, 2016 4:39 pm
Thanks guy little love tap from a hammer got it going but I need to get a spare solenoid so this doesn't happen when I really need reverse or trim.
Tue Dec 13, 2016 5:17 pm
