It is currently Mon Sep 22, 2025 4:15 am
Reply to topic  [ 15 posts ]
 Stock 37 efi prop ?
Post Stock 37 efi prop ?
I know I'm fixen to get a ear full but can I run a hammer prop on stock 37 efi?
Wed Feb 22, 2017 5:08 pm
Post Re: Stock 37 efi prop ?
You won't be happy with the hammer stock. Big blade with some cup what worked best for me in Stock form.
Sent from my SM-G930V using Tapatalk
Wed Feb 22, 2017 6:36 pm
You might be able to, depends a lot on weight, type of hull and if motor turns above 4000 rpm with your normal load. I would recommend trying one before you buy. BPS does have a return policy if prop doesn't work on you rig. If it isn't damaged in any way.
Wed Feb 22, 2017 6:42 pm
You really need a couple extra HP to turn it effectively IMO. If you have an exhaust you might be ok because the couple extra HP. What size boat are you pushing?
Wed Feb 22, 2017 7:25 pm
GTR 1854 extreme run 4300 rpm just me
Wed Feb 22, 2017 8:02 pm
I have an 1851 and I won't run a hammer until I do mods. I would think you're rig would preform similar to mine. I would Stick with a big blade and have it worked up a little.
Wed Feb 22, 2017 8:16 pm
Wed Feb 22, 2017 8:19 pm
Wed Feb 22, 2017 8:32 pm
Wed Feb 22, 2017 8:40 pm
Who done the work on the prop TPerkins and best place to buy 2 blade?
Wed Feb 22, 2017 8:42 pm
Wed Feb 22, 2017 8:47 pm
Jay Dore worked mine. I ordered my last one from boat Dr.
Wed Feb 22, 2017 9:05 pm
Thu Feb 23, 2017 4:24 pm
Might want to check your hull, could of developed a hook, or foam under floor is soaked up with water. Also check to see what gears are in drive. With mods you have you should be able to pull Hammer prop easily. I can get upto the 4700 rev. limiter with 38/47 gears on my moded BD45 running a Hammer prop. Motor is on a 1648 Alumacraft riveted Jon.
Thu Feb 23, 2017 5:40 pm
Thu Feb 23, 2017 6:41 pm
