| Stock 37 efi prop ? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=69898 |
| Author: | ducman84 [ Wed Feb 22, 2017 5:08 pm ] |
| Post subject: | Stock 37 efi prop ? |
I know I'm fixen to get a ear full but can I run a hammer prop on stock 37 efi? Sent from my iPhone using Tapatalk |
| Author: | TPerkins [ Wed Feb 22, 2017 6:36 pm ] |
| Post subject: | Re: Stock 37 efi prop ? |
You won't be happy with the hammer stock. Big blade with some cup what worked best for me in Stock form. Sent from my SM-G930V using Tapatalk |
| Author: | DENNYEDWARDS [ Wed Feb 22, 2017 6:42 pm ] |
You might be able to, depends a lot on weight, type of hull and if motor turns above 4000 rpm with your normal load. I would recommend trying one before you buy. BPS does have a return policy if prop doesn't work on you rig. If it isn't damaged in any way. |
| Author: | Roostertail3 [ Wed Feb 22, 2017 7:25 pm ] |
You really need a couple extra HP to turn it effectively IMO. If you have an exhaust you might be ok because the couple extra HP. What size boat are you pushing? |
| Author: | ducman84 [ Wed Feb 22, 2017 8:02 pm ] |
GTR 1854 extreme run 4300 rpm just me Sent from my iPhone using Tapatalk |
| Author: | Roostertail3 [ Wed Feb 22, 2017 8:16 pm ] |
I have an 1851 and I won't run a hammer until I do mods. I would think you're rig would preform similar to mine. I would Stick with a big blade and have it worked up a little. |
| Author: | Gunshinestate407 [ Wed Feb 22, 2017 8:19 pm ] |
| Author: | msm8281 [ Wed Feb 22, 2017 8:32 pm ] |
| Author: | TPerkins [ Wed Feb 22, 2017 8:40 pm ] |
| Author: | ducman84 [ Wed Feb 22, 2017 8:42 pm ] |
Who done the work on the prop TPerkins and best place to buy 2 blade? Sent from my iPhone using Tapatalk |
| Author: | ducman84 [ Wed Feb 22, 2017 8:47 pm ] |
| Author: | TPerkins [ Wed Feb 22, 2017 9:05 pm ] |
Jay Dore worked mine. I ordered my last one from boat Dr. Sent from my SM-G930V using Tapatalk |
| Author: | Gunshinestate407 [ Thu Feb 23, 2017 4:24 pm ] |
| Author: | DENNYEDWARDS [ Thu Feb 23, 2017 5:40 pm ] |
Might want to check your hull, could of developed a hook, or foam under floor is soaked up with water. Also check to see what gears are in drive. With mods you have you should be able to pull Hammer prop easily. I can get upto the 4700 rev. limiter with 38/47 gears on my moded BD45 running a Hammer prop. Motor is on a 1648 Alumacraft riveted Jon. |
| Author: | Gunshinestate407 [ Thu Feb 23, 2017 6:41 pm ] |
