BB tearing up motor http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=69913 |
Author: | fireman1562003 [ Fri Feb 24, 2017 10:41 am ] |
Post subject: | BB tearing up motor |
whats this I hear that a BB with vibrate so bad and tear your motor up and cause lower unit to crack ? |
Author: | TPerkins [ Fri Feb 24, 2017 10:44 am ] |
Post subject: | Re: BB tearing up motor |
I would think anybody with any kind of sense would realise the prop is off balance far before it gets bad enough to cause damage to the LU. Sent from my SM-G930V using Tapatalk |
Author: | Will C [ Fri Feb 24, 2017 10:48 am ] |
Some of them do vibrate like a sumbitch. I cant comment on them hurting parts or not. Ive ran some that were clean with little vibration. One of the worst ones on a gtr was WAY bad. I checked weight and pitch for balance and its was dead on. I cant explain why some are worse than others |
Author: | fireman1562003 [ Fri Feb 24, 2017 10:49 am ] |
yea mine don't seem to vibrate any worse then the stock 3 blade . im with though you should be able to tell something is wrong way before you tear it up |
Author: | TPerkins [ Fri Feb 24, 2017 10:51 am ] |
But when they do this it's a whole nother story. Sent from my SM-G930V using Tapatalk |
Author: | fireman1562003 [ Fri Feb 24, 2017 10:52 am ] |
yea that's not good !! keep extra prop in boat |
Author: | BlueShamu [ Fri Feb 24, 2017 6:56 pm ] |
Vibration in these motors will wreck some stuff....and it's not limited to any one particular prop manufacturer. You get prop wear, you get out of balance. Out of balance causes vibration. Vibration causes fatigue. Fatigue leads to failure....somewhere. Depending on the brand motor will dictate where it fails. |
Author: | TPerkins [ Fri Feb 24, 2017 8:45 pm ] |
I've seen a pile of big blades broken identical to the one I posted. Sent from my SM-G930V using Tapatalk |
Author: | CypressCritter [ Sat Feb 25, 2017 8:50 am ] |
I got one that looks just like that one! Had less than 20 hrs. |
Author: | Quack N Stack [ Tue Feb 28, 2017 6:14 pm ] |
It dont matter what prop you got, if it breaks or goes to far outa balance you shit outa luck anyway...IMG_1024.JPGIMG_1025.JPGIMG_1026.JPG Sent from my iPhone using Tapatalk |
Author: | CypressCritter [ Wed Mar 01, 2017 9:24 am ] |
How hours on the motor and prop? Is that something that will happen often to the cast lower housing? |
Author: | Quack N Stack [ Wed Mar 01, 2017 10:43 am ] |
Author: | caddobrook [ Wed Mar 01, 2017 11:01 am ] |
Author: | Quack N Stack [ Wed Mar 01, 2017 12:40 pm ] |
