It is currently Mon Sep 22, 2025 12:37 am
[ 6 posts ] |
d_white
 Bad zert?
Do zerts go bad? Greased my HDR shaft a couple of days ago. Let the excess bleed out. Ran some this weekend and then noticed this. Also, does it look like water is mixed with the grease? Will replacing the fitting likely fix this? It feels like it's screwed in tight and the grease seemed to have come out the top.
Mon Mar 27, 2017 9:31 am |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
 Re: Bad zert?
Sometimes the ball will stick down and allow grease out the tip. Did you grease it the proper way by removing the screw in the outdrive casting and removing the nut on the prop end of the shaft? You may have over greased it and had to much pressure in the outdrive tube? If you do that to many times you'll blow the seals out both ends and have a damn mess in the belt box.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
Mon Mar 27, 2017 10:06 am |
d_white
 Re: Bad zert?
I removed the upper screw to vent it but not the prop nut
Mon Mar 27, 2017 11:23 am |
Smoke
 Re: Bad zert?
Did you let the motor run while in gear for a bit after greasing with the screw out? It will work out a bit of the grease if you over filled it. Most tend to over fill while greasing, that's why I ask.
Tue Mar 28, 2017 4:34 am |
Smoke
 Re: Bad zert?
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
 Re: Bad zert?
Bad zert! Cheap easy fix. A zert should not let grease come out of it. Be sure when greasing, wipe off zert and grease gun tip to clean it of foreign material. That could also keep the little ball from sealing off after greasing. Just takes 1 little grain of sand and leaky-leaky.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Tue Mar 28, 2017 8:03 am |
[ 6 posts ] |
