27hp pd prop question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=7010 |
Author: | mharms909 [ Sun Jan 10, 2010 10:07 am ] |
Post subject: | 27hp pd prop question |
Proper diameter for 27hp prodrive prop and What advantage is the 3 blade giving over the 2 blade? I am having extreme issues with hole shot and load carrying running 27pd on 1548 boat and while i get 25 with me and an empty boat add weight for a duck hunt and boat barely planes out if at all. motor runs fine Matt ![]() |
Author: | OwenDickeson [ Sun Jan 10, 2010 10:54 am ] |
Post subject: | Re: 27hp pd prop question |
You need a longer boat for planing out any real load with that 27 |
Author: | mharms909 [ Sun Jan 10, 2010 1:29 pm ] |
I am kind of dubious about the longer boat issue. I would imagine that the contact patch of a flat bottom boat on plane that is one foot or 2ft longer is not going to be any different than that of my 15ft boat. Is it a CG issue or something else entirely as the RPMS are affected by this whole issue. Matt |
Author: | OwenDickeson [ Sun Jan 10, 2010 4:34 pm ] |
Author: | mharms909 [ Sun Jan 10, 2010 4:59 pm ] |
Just out of curiosity what length of boat is suggested for a 27hp PD? |
Author: | OwenDickeson [ Sun Jan 10, 2010 5:19 pm ] |
17 or 18 ft or so. |
Author: | EasTexDux88 [ Tue Jan 12, 2010 2:54 pm ] |
1848 would do good with a 27 |
Author: | mudgrappler [ Tue Jan 12, 2010 7:06 pm ] |
I'd go no less than 18'. Hell Crews used to run a 20' with a 27 and it would plane a hell of a load. And if your thinking a 18' is to long...your wrong. you can put a 18' boat anywhere you can put a 15' boat. |
Author: | mharms909 [ Thu Jan 14, 2010 6:07 pm ] |
My only problem is the having to buy another boat that is something i dont want to do or can't right now. What about adding pods or customizing a hunt deck on the back of my boat lenghtening it by aobut 18 to maybe 20 inches? Matt |
Author: | OwenDickeson [ Thu Jan 14, 2010 6:16 pm ] |
just save the money your gonna spend on that and wait til you can afford a bigger boat... |
Author: | mudgrappler [ Thu Jan 14, 2010 7:28 pm ] |
Author: | hunterg [ Mon Jan 25, 2010 9:37 pm ] |
i used to run a 27 on a 15x48 and had the same problem, then switched to a 17x48 and it made a HUGE difference. |
