It is currently Sat Nov 15, 2025 4:17 am
Reply to topic  [ 3 posts ]
 Pro Drive lower unit leak question
Post Pro Drive lower unit leak question
Hello I recently did The long shaft conversion on my 2004 27 hp. I have a leak around the collar this would be lower unit oil correct?
Thu Mar 23, 2017 10:51 am
Post Re: Pro Drive lower unit leak question
Yes. This is indicating you probably have bad lower prop seals that are taking in water into the lower unit. Water is heavier than oil so it will force oil out of the top.
Thu Mar 23, 2017 12:19 pm
Thu Mar 23, 2017 2:01 pm
