It is currently Sun Sep 21, 2025 10:43 pm
Reply to topic  [ 18 posts ]
 Boat won't turn! Help!!
Post Boat won't turn! Help!!
I recently purchased the mud buddy hdr 44 efi. It comes with the new raptor 3 blade prop. Seems like a good prop but I'm having trouble making my boat turn at WOT. It wants to slide bad. Boat is a custom boat with the triple taper chines. Do y'all think a big blade prop could help me??? Instead of the raptor 3 blade. Feels like it just wants to push straight forward. Any advise appreciated
Wed Apr 26, 2017 7:52 pm
Post Re: Boat won't turn! Help!!
Let off the throttle some to get your boat to bite.
When it's up on plane wide open, the Chines won't grab enough water when you start your turn until you lose enough speed so it sinks back into the water some.
Wed Apr 26, 2017 7:59 pm
I just feel like it should turn at wot. It also wants to side hop when I turn
Wed Apr 26, 2017 8:44 pm
Should have bought a gatortrax
Wed Apr 26, 2017 9:28 pm
Or a v bottom boat and an outboard hear they cut like a knife
"There's nothing a duck hunter hates more than another duck hunter."
Wed Apr 26, 2017 9:32 pm
If it's 48" or wider, and isn't 1000lbs unloaded, it's going to have a tendency to slide at wot unless it has reverse chines. Some more than others, and some are lucky with the way they bite and don't slide at all. Shift weight to the direction you're turning to try to lift the outside of the boat and make the chine bite more, but it's likely not going to help a whole lot
Wed Apr 26, 2017 9:53 pm
Your feelings don't apply to physics.
Gatortail Extreme 1854 w/ GTR 37 efi or 90hp Yamaha
Godevil 1860 w/ gd 35 sd with a Mikuni Carb Sold
Thu Apr 27, 2017 2:42 am
Almost all boat slide its just a matter of how much. A true flat bottom will slide and depending on speed really slide. I got a 24x72 aluminum flat w/150 hp if its light loaded and going over about 40 mph --- had to turn out turn then turn back and it does get a better bite. BTW nothing wrong with turning left to go right!
Thu Apr 27, 2017 7:54 am
Thu Apr 27, 2017 12:23 pm
Thu Apr 27, 2017 1:32 pm
Thu Apr 27, 2017 1:37 pm
You should probably just sell the motor.
I'll give you $6K for it.
Thu Apr 27, 2017 6:59 pm
you just got the boat right? go run it for a while, then u will figure it out.
most folks hate their boats for a while till they learn how to run them. it's normal. once you learn how to play the slide it won't bother you much at all.
good luck!
Thu Apr 27, 2017 7:28 pm
You can do some pretty funky stuff when you're able to slide the boat...
Thu Apr 27, 2017 7:50 pm
And by funky he means hella power slides!
Thu Apr 27, 2017 8:16 pm
Kool-Aid Brigade
www.southernfowler.com
Fri Apr 28, 2017 9:11 am
Fri Apr 28, 2017 11:33 am
^^^^ haha!
Semper Fi
16x38 WC Skiff 35 MB HD
Sun Jun 11, 2017 5:47 pm
