quackerdown
Go devil pressure lubricator
Just bought a 23 go devil surface druve and noticed after the first several uses water in the top of the lubricator above the grease. Is this normal?
Mon Jun 12, 2017 10:46 am |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
Re: Go devil pressure lubricator
The lubricator GoDevil uses has to be vented to atmosphere to work properly. As long as the grease under the plunger is clean and in good shape, a little water won't hurt a thing and is normal. I typically pull my lubricator, flush the drive tube with fresh grease, clean the lubricator itself and put it back together, every oil change or so. It's easy and it ensures whatever going into your out drive is clean and dry.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Mon Jun 12, 2017 9:39 pm |
kirk
Joined: Thu Apr 18, 2013 5:52 pm Posts: 870 Location: SW LA
I asked setx longtail the same question this weekend! I'd go with what he says, although it bothers the heck out of me seeing water in the grease lubricator even if it is not actually mixed with the grease
Tue Jun 13, 2017 5:36 pm |
SETx Longtail
Alemite makes a sealed lubricator. It's aluminum and has a nitrogen charge inside it to force the grease out. Only problem is it's you can't see the grease level so you really don't know what you're working with. The clear spring action grease cup we have is annoying with the water and trash on top but as long as everything looks ok underneath the plunger you're fine. Just clean it ocassionally.
Tue Jun 13, 2017 7:03 pm |
quackerdown
It does seem weird but called go devil and they said its normal too. thanks for the responses
Tue Jun 13, 2017 8:09 pm |
flint87
Ah shit, all my godevil motors had a little water in the grease even inside the shaft tube. Never hurt anything that I know of. My last sd and current longtail if I take off the greaser to flush the tube I get about a teaspoon of water and brass shaving from the bushings on the fest few pumps of the grease gun
Tue Jun 13, 2017 8:48 pm |
Russ
Tue Jun 13, 2017 9:10 pm |
brycecheramie
Speaking of pressure lubricators.... Where can I get one? Does it need to be from godevil? I just broke mines today
Tue Jun 13, 2017 11:00 pm |
SETx Longtail
Wed Jun 14, 2017 5:42 am |
brycecheramie
What is the "right" spring? I see there's standard and heavy duty. I'm thinking about tearing my whole outdrive apart and rebuilding it all together for piece of mind. Never got my hand dirty on a GDSD though.
Wed Jun 14, 2017 6:16 am |
SETx Longtail
The outdrives are stupid simple... they're really easy to service top to bottom. Run the lightest spring in that lubricator for our uses or else it may push past the seals. I actually had my whole outdrive off the motor not long ago it was a simple job. It helps having a hand to hang that heavy bastard though when you go back together.
Wed Jun 14, 2017 6:33 am |
flint87
Wed Jun 14, 2017 2:46 pm |
SETx Longtail
Two people are plenty. I almost had it by myself but couldn't rope the bolt holes while holding everything else up.
Wed Jun 14, 2017 3:12 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
Setx is corn fed!
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
Wed Jun 14, 2017 3:44 pm |
flint87
Wed Jun 14, 2017 5:58 pm |
brycecheramie
http://www.partdeal.com/alemite-visi-lu ... aQodgigHVAThis looks like it. But it comes with multiple springs. Will just put the standard spring in it.
Wed Jun 14, 2017 7:01 pm |
brycecheramie
https://www.amazon.com/Alemite-B1741-A- ... lubricatorFound this on amazon. How do I know that the fitting will fit on the GDSD? Is it just standard?
Wed Jun 14, 2017 7:09 pm |
SETx Longtail
GD uses a 1/8" NPT threaded hole in the drive tube. I'd personally get the lightest spring you can. I think it's something like 2psi
Wed Jun 14, 2017 7:52 pm |
