It is currently Mon Sep 22, 2025 12:17 pm
Reply to topic  [ 18 posts ]
 Go devil pressure lubricator
Post Go devil pressure lubricator
Just bought a 23 go devil surface druve and noticed after the first several uses water in the top of the lubricator above the grease. Is this normal?
Mon Jun 12, 2017 10:46 am
Post Re: Go devil pressure lubricator
The lubricator GoDevil uses has to be vented to atmosphere to work properly. As long as the grease under the plunger is clean and in good shape, a little water won't hurt a thing and is normal. I typically pull my lubricator, flush the drive tube with fresh grease, clean the lubricator itself and put it back together, every oil change or so. It's easy and it ensures whatever going into your out drive is clean and dry.
-Custom pool noodle
-stage 4 water wings
Mon Jun 12, 2017 9:39 pm
I asked setx longtail the same question this weekend! I'd go with what he says, although it bothers the heck out of me seeing water in the grease lubricator even if it is not actually mixed with the grease
Tue Jun 13, 2017 5:36 pm
Alemite makes a sealed lubricator. It's aluminum and has a nitrogen charge inside it to force the grease out. Only problem is it's you can't see the grease level so you really don't know what you're working with. The clear spring action grease cup we have is annoying with the water and trash on top but as long as everything looks ok underneath the plunger you're fine. Just clean it ocassionally.
-Custom pool noodle
Tue Jun 13, 2017 7:03 pm
It does seem weird but called go devil and they said its normal too. thanks for the responses
Tue Jun 13, 2017 8:09 pm
Ah shit, all my godevil motors had a little water in the grease even inside the shaft tube. Never hurt anything that I know of. My last sd and current longtail if I take off the greaser to flush the tube I get about a teaspoon of water and brass shaving from the bushings on the fest few pumps of the grease gun
Tue Jun 13, 2017 8:48 pm
Tue Jun 13, 2017 9:10 pm
Speaking of pressure lubricators....
Where can I get one? Does it need to be from godevil?
I just broke mines today :roll:
Tue Jun 13, 2017 11:00 pm
http://www.partdeal.com/alemite-visi-lu ... oCT87w_wcB
Just make sure you run the right spring in it.
-Custom pool noodle
Wed Jun 14, 2017 5:42 am
What is the "right" spring? I see there's standard and heavy duty.
I'm thinking about tearing my whole outdrive apart and rebuilding it all together for piece of mind.
Never got my hand dirty on a GDSD though.
Wed Jun 14, 2017 6:16 am
The outdrives are stupid simple... they're really easy to service top to bottom. Run the lightest spring in that lubricator for our uses or else it may push past the seals. I actually had my whole outdrive off the motor not long ago it was a simple job. It helps having a hand to hang that heavy bastard though when you go back together.
-Custom pool noodle
Wed Jun 14, 2017 6:33 am
Wed Jun 14, 2017 2:46 pm
Two people are plenty. I almost had it by myself but couldn't rope the bolt holes while holding everything else up.
-Custom pool noodle
Wed Jun 14, 2017 3:12 pm
Setx is corn fed!
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Wed Jun 14, 2017 3:44 pm
Wed Jun 14, 2017 5:58 pm
http://www.partdeal.com/alemite-visi-lu ... aQodgigHVA
This looks like it.
But it comes with multiple springs. Will just put the standard spring in it.
Wed Jun 14, 2017 7:01 pm
https://www.amazon.com/Alemite-B1741-A- ... lubricator
Found this on amazon.
How do I know that the fitting will fit on the GDSD? Is it just standard?
Wed Jun 14, 2017 7:09 pm
GD uses a 1/8" NPT threaded hole in the drive tube. I'd personally get the lightest spring you can. I think it's something like 2psi
-Custom pool noodle
Wed Jun 14, 2017 7:52 pm
