It is currently Sat Nov 15, 2025 2:02 am
Reply to topic  [ 3 posts ]
 Mudbuddy 35 HD bearing and seal replacement info??
Post Mudbuddy 35 HD bearing and seal replacement info??
After searching I've found nearly no info on how to replace bearings and seals on my HAD with 3/4 hex shaft. Does anybody have a link to a how-to? Also heard the parts can be sourced locally versus buying directly from MB or BPS...can someone confirm this?? Thanks fellas.
Sun Jul 30, 2017 3:40 pm
Post Re: Mudbuddy 35 HD bearing and seal replacement info??
The bearings, yes, but the seals are in the cap, so just buy it from mb. The front seal can probably be sourced, but if you're buying the cap, may as well get the front from them as well. Pm sent with contact info. I'm not gonna do a big writeup because I can't take pics, but I can talk you through it.
#TheGhostBoat
Sun Jul 30, 2017 5:00 pm
Should be something on BPS page under tech tips. At least there used to be. Its not difficult either way.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Jul 31, 2017 10:22 am
