Mudbuddy 35 HD bearing and seal replacement info??
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=70915
Author:  Motostar929rr [ Sun Jul 30, 2017 3:40 pm ]
Post subject:  Mudbuddy 35 HD bearing and seal replacement info??
After searching I've found nearly no info on how to replace bearings and seals on my HAD with 3/4 hex shaft. Does anybody have a link to a how-to? Also heard the parts can be sourced locally versus buying directly from MB or BPS...can someone confirm this?? Thanks fellas.
Author:  Russ [ Sun Jul 30, 2017 5:00 pm ]
Post subject:  Re: Mudbuddy 35 HD bearing and seal replacement info??
The bearings, yes, but the seals are in the cap, so just buy it from mb. The front seal can probably be sourced, but if you're buying the cap, may as well get the front from them as well. Pm sent with contact info. I'm not gonna do a big writeup because I can't take pics, but I can talk you through it.
#TheGhostBoat
Author:  Smoke [ Mon Jul 31, 2017 10:22 am ]
Should be something on BPS page under tech tips. At least there used to be. Its not difficult either way.
