It is currently Mon Jun 03, 2024 4:51 pm
[ 5 posts ] |
G4 Prodrive auto reverse issue
woodie_slayer
Has anyone ever had their prodrive trim down a lot while shifting to reverse? I was told it might be the solenoid or the pump.
Fri Sep 29, 2017 8:32 am |
cb5331
Re: G4 Prodrive auto reverse issue
Newer ones just use a single pump, right? If yes, then I would say there is an issue with the solenoid.
Fri Sep 29, 2017 10:03 am |
woodie_slayer
Yes,its just one pump.If it is the solenoid,how would know if its going out? Thanks
Fri Sep 29, 2017 10:16 am |
cb5331
If you hit the switch to put the LU in reverse and it moves the trim, I would say the solenoid has already gone out. Give pd a call, they may be able to give you some other things to check first, but I think the solenoid is bad.
Fri Sep 29, 2017 10:42 am |
woodie_slayer
Thanks man ill check it out.
Fri Sep 29, 2017 10:47 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 86 guests |
