Gator Tail Cracked Shaft Help http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=71652 |
Author: | HeytDuck [ Thu Nov 30, 2017 11:25 am ] |
Post subject: | Gator Tail Cracked Shaft Help |
Last weekend I noticed a small crack in my shaft behind the prop and in front of the seal. I stuck a shim down it and measured the depth to 1/16. I let it ride for the weekend and the motor performed without missing a beat. Ive been running a GT 3 blade with a lot of load recently, if that matters. Is this something I should be worried about or has anyone else seen this before? Thanks |
Author: | 50fps [ Fri Dec 01, 2017 8:57 am ] |
Post subject: | Re: Gator Tail Cracked Shaft Help |
Have you contacted the manufacturer? |
Author: | Russ [ Fri Dec 01, 2017 12:53 pm ] |
Get it fixed. It would suck to have that get worse when you're trying to use it. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
