on da bayou
 Gear teeth on my 2012 gtr
I have a 2012 35 gtr With hydraulic reverse wanting to know how many teeth or on the top pulley and how many teeth is on lower pulley on a stock gtr also what is the prop size and Pitch it is in a two blade and a three blade if any one know
Mon Jan 08, 2018 5:41 pm |
bluesky2012
 Re: Gear teeth on my 2012 gtr
Take the transmission cover off. It'll have a 48 stamped on either the right or left side if it is 48
Mon Jan 08, 2018 6:05 pm |
on da bayou
bluesky2012 wrote: Take the transmission cover off. It'll have a 48 stamped on either the right or left side if it is 48
Sent from my iPhone using Tapatalk Pro thanks what u think the bottom one is Sent from my iPhone using Tapatalk
Mon Jan 08, 2018 8:24 pm |
bluesky2012
The bottom is 48. The top is what ever you count to. I don't think the top has ever changed. I think the ones changed around 2012 went from 42 to 48 but I may be backwards.
Mon Jan 08, 2018 8:27 pm |
Russ
Joined: Mon Dec 31, 2012 11:07 pm Posts: 4223 Location: West Monroe, LA
The bottom used to be 45, changed to 48 around that time. The top is 36, I think. Marcus will be along shortly to correct me if it's 38.
Mon Jan 08, 2018 8:36 pm |
on da bayou
bluesky2012 wrote: The bottom is 48. The top is what ever you count to. I don't think the top has ever changed. I think the ones changed around 2012 went from 42 to 48 but I may be backwards.
Sent from my iPhone using Tapatalk Pro thanks for the help do u know the prop size is 11 or 12 I have a power tech but shows no size on a stock gtr 35 Sent from my iPhone using Tapatalk
Mon Jan 08, 2018 8:37 pm |
Russ
12x10
Mon Jan 08, 2018 8:39 pm |
on da bayou
Russ wrote: 12x10
#CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor thanks I measured mine today it measured 11 so I’m short 1” Sent from my iPhone using Tapatalk
Mon Jan 08, 2018 8:40 pm |
bluesky2012
If Russ says it is, then it is. Thanks for the correction on 45 and not 42. Drinking beers and watching Alabama hopefully lose doesn't make for a strong memory of obscure facts.
Mon Jan 08, 2018 8:43 pm |
on da bayou
If u always have to push away with the tiller handle from u which way should I bend the tabs thanks
Mon Jan 08, 2018 8:48 pm |
bluesky2012
Away from you. Check your weight distribution first and also prop plays into effect. Since you have a worn prop, may want to wait till you have a new one and see how that plays in.
Mon Jan 08, 2018 8:51 pm |
Russ
Trim level affects the felt torque a lot, and a fresh prop will change where it's trimmed for best thrust. Unless you're gonna use that prop a while, just wait on the bending stuff.
Mon Jan 08, 2018 8:55 pm |
on da bayou
Thanks baggy’s got my prop now to get work
Mon Jan 08, 2018 9:09 pm |
MaXXis85
Joined: Wed Jan 14, 2009 7:23 am Posts: 6130 Location: Tarkington, TX
Top gear is 38 Current bottom is 48. Used to be 45 lower, but was changed around 2011-2012 ish. The CDI motors additional charging system put more load on these units aswell as larger boats, 3 blade propellers were coming out; so they needed a lower gear ratio. 38/45 = 1.18:1 38/48 = 1.26:1
Tue Jan 09, 2018 6:18 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 819 Location: Jefferson TX
I have a 2011 GTR CDI
its a 38/45 and came stock with a power tech 12x10
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/35 GTR
Tue Jan 09, 2018 10:39 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
MaXXis85 wrote: Top gear is 38 Current bottom is 48. Used to be 45 lower, but was changed around 2011-2012 ish. The CDI motors additional charging system put more load on these units aswell as larger boats, 3 blade propellers were coming out; so they needed a lower gear ratio. 38/45 = 1.18:1 38/48 = 1.26:1 To be exact they changed the bottom gear for 2013!
cupped up wrote: Nigqers, dean. That's what happened. A whole pile of useless phucking piece of chit nigqers. Most of whom are probably fed by welfare. See the kind of world your beloved democrats are creating? Lovely, isn't it?
That place needs a 24 hour purge like that movie. Let em all kill each other off. Then when that's done, drop a nuke on that shit hole and be done with it. Chocolate city.
2013 1746 gator series wit 35 GTR - JUNK #3940
Tue Jan 09, 2018 1:51 pm |
on da bayou
Sent from my iPhone using Tapatalk Pro on the cover it will be stamp or the trans itself Sent from my iPhone using Tapatalk
Thu Jan 11, 2018 7:41 pm |
MaXXis85
Port side top of belt box.
Fri Jan 12, 2018 7:36 am |
