| HDR gasket http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=71989 |
| Author: | Roostertail3 [ Tue Jan 30, 2018 3:42 pm ] |
| Post subject: | HDR gasket |
Searched without finding what I was looking for so could some help me out with a part number for a gasket for the HDR belt / drive case. Mine leaks water and I can't seem to find where it's leaking in. I want to replace the gasket and put a bead of RTV down. Any help would be appreciated. |
| Author: | riverrat00 [ Wed Jan 31, 2018 2:07 am ] |
| Post subject: | Re: HDR gasket |
Just use the black rtv should be good to go. Also seal all of the bolts on the motor side where the housing slides up an down for belt tensioning. |
| Author: | Roostertail3 [ Wed Jan 31, 2018 4:43 am ] |
I'll give that a try, thanks. |
| Author: | BoatDR [ Thu Feb 01, 2018 9:57 am ] |
1) it is 3/32" rubber cord. it is sold in bulk and it is cut to fit. It would be best to use both a sealant and replace the "gasket" 2) dont use rtv. marine silicone will make a much stronger bond. 3) get rid of that foam gasket between the lower drive and the clutch cover, and put a liberal bead of silicone on that surface to seal them. Most of the water leaks we have found were due to that gasket between the upper and lower covers. |
| Author: | Roostertail3 [ Thu Feb 01, 2018 3:54 pm ] |
Thanks I'm going to change oil grease and replace the gasket/Oring this weekend. |
