It is currently Sun Sep 21, 2025 1:41 pm
Reply to topic  [ 4 posts ]
 Worked Prop
Post Worked Prop
Need a few others experience. Running a 1751 Prodigy with a 4400 HDR. Motor has boat dr heads, Peltier 308 +5 cam, voodoo exhaust, bug carb and intake. I’m turning a worked baggy big blade (one inch and cup added) at 4500+ rpm and 33mph. Can sling a hammer in the same rpm range. Boat does not loose speed as I trim so I’m guessing more pitch would work? Looked into the raptor or worked merc but don’t like them in the vegetation
17/51 Prodigy Elite 4400 HDR
Wed Mar 14, 2018 7:42 am
Post Re: Worked Prop
I sling a hammer worked over by baggy 55mag hdr 1754 prodigy. Runs slower but better in clay, hard bottoms. BB is fast but not to wear resistant. If your in it for just you already mentioned the 3 blade
Sent from my SM-N950U using Tapatalk
Sat Mar 17, 2018 3:07 pm
I hear ya, just worried about clogging it up. Guess I’ll have to keep the impact on the boat and switch them lol. Maybe I’m expecting a little too much out of the motor. I’m changing the gear ratio from 38/47 to a 46 on bottom so I’ll go from there.
Mon Mar 19, 2018 4:08 am
I run a gatortail 3 blade (power tech) and it goes through the vegetation and mud just as well as anything else I've ran. It's been worked by baggy as well, which is a must have. The three blade with the mods you have should add a couple mph for you I would think bro.
Tue Apr 24, 2018 7:44 pm
