It is currently Thu Mar 28, 2024 6:13 pm
Reply to topic  [ 29 posts ]
 Gatortail fat blade
Post Gatortail fat blade
Got a gatortail 2 blade fat blade prop coming in sometime this week. It looks similar to a hammer in size. I'm going to see what it does stock and then get baggy to do his magic on it. Anyone have experience running this prop?
Tue May 22, 2018 9:57 am
Post Re: Gatortail fat blade
I've had good luck with the fat blade props.... works great for my application....
trhkr2
Mon May 28, 2018 7:49 am
Yeah man, unworked I was able to turn it 30mph at 4500. Once it's worked it will scoot well I'm sure
Mon May 28, 2018 5:03 pm
Hey, did you get that prop back from baggy yet & installed ? Hows it run?
Sent from my SM-G955U using Tapatalk
Wed May 30, 2018 8:48 pm
No not yet bro. I want to run the boat with that prop unworked one more time with the cut skeg I ordered, once I get numbers with it, I'm going to bring it to him and let you know how it does bro
Thu May 31, 2018 8:49 am
Thu May 31, 2018 10:21 am
what are the specs on the Fat Blade? the webpage doesn't give any info.
Thu May 31, 2018 12:22 pm
Cavitation 46, 9 pitch. That is unworked.
Sun Jun 03, 2018 9:00 pm
Just got my worked fat blade back from baggy and ran it today. He worked it to a 10 pitch, added heavy cupping, sharpened the blades, took .25 inches off of each blade, and polished it. Gained 3 mph in shallow water and 5 in deep (yes, for some reason my skiff runs better in deep water). I'm running 32 in shallow and 34-35 in deep. Holeshot is the best ive ever been in hands down and got the boat up to top speed in about 5 seconds. Very happy with it. put my dad In the boat and ran the exact same speeds, so it carries a load very well.
Wed Jun 13, 2018 4:37 pm
Who is baggy? And how can I get ahold of him? I’m getting a 37efi level 3 and wanting to see what best 2 blade is for it.
35 GTR on Uncle J 18/54
Fri Jun 22, 2018 7:31 pm
868-0103 is his number bro. He owns a prop shop in Houma. Best around. Give him a call and he will point you in the right direction
Fri Jun 22, 2018 8:01 pm
WHat kind of rooster tail you throwing with this prop?
I got to run a 40 the other day and I threw my baggy 2 blade from my 37 on it. I could get the prop out the water and cavitate it easily and the roost it threw was really really weird compared to other props ive run.
Normally on my 37 I throw a roost strait up and back, but on the 40 it seemed like it was coming off of the opposite side of the prop and shooting out to the side, no matter how I trimmed it.
The weirdest thing was how easy it was to cavitate it, but it made a massive difference over the stock 3 blade.
Hows your prop running so far? are you able to cavitate it easy like this one?
Mon Aug 20, 2018 11:40 am
My fat blade throws a lot to the side but the main rooster tail is straight out the back. I run it about 4400-4500 for optimal speeds on my rig. It carries a load like nothing else though imo
Mon Aug 20, 2018 6:30 pm
Anybody ever have a fat blade cut to 9" diameter? Will be running a modded GTR 25 BB, and have the need for a 9" prop at times. Since I can crank out more hp than stock I'm wondering if using what the 35-37 hp stock rigs would use could give more performance.
Or any other recommendations for a 9" prop turned by more than 25hp?
Wed Aug 22, 2018 5:13 pm
Call baggy he will know exactly what you need. You won’t be able to turn these props, they are all 12.25x10 and bigger. Baggy would be the man to have cut and cup it though.
Fri Aug 24, 2018 8:08 am
Yep, he is right, baggy will point you in the right direction bud
Fri Aug 24, 2018 9:00 am
Mine really pulled hard away from my hand and I got 23mph on my 1854 Stumpjumper. Backed up pretty good and it got on plane good but it was slow. Running a 40hp Gatortail.
Tue Aug 28, 2018 6:58 am
Is that stock with the wheel or did you get it worked bud?
Tue Aug 28, 2018 9:38 am
Wed Aug 29, 2018 11:07 am
What motor are you running? 12 pitch with cup is perfect for my 40
Wed Aug 29, 2018 12:04 pm
Wed Aug 29, 2018 6:51 pm
Got my Fat Blade back from Baggy this week. Took it out today. Went from 23mph to 26 sometimes 27 in deep water. Zero Tiller Torque. It is now as fast as my 3 Blade. Backs up pretty good but the main thing is I don't have to Trim down to take off. I set my Trim wide open and left it there. That thing bit and took off no problem Trimmed up to run. I am happy and wondering if I should send in the 3 Blade.
Sun Oct 14, 2018 7:22 pm
Baggy is the best out there for a reason bro. That's some very good gains
Sun Oct 14, 2018 8:43 pm
Took my worked Fat Blade out with a heavy boat last Sunday. My Boat is heavy anyway but I had two people with three big tackle boxes, 14 Jug lines, 10 fishing poles, gallon of stink bait, a gallon water jug, a cooler with ice, gaff, a 20lb anchor, and a full Livewell containing about 10 good eating size catfish. Got 24.5 mph down from 26 just me. I did not think this was bad at all.
Tue Oct 23, 2018 2:14 pm
That's damn good speeds bro. That fat blade is not a speed prop, but it pushes a load like a beast. It does extremely well in mud and in reverse as well
Tue Oct 23, 2018 3:42 pm
You know what I really liked was the fact I did not have to trim down to take off.
Tue Oct 23, 2018 3:54 pm
I agree, that fat blade just eats and pushes a load
Tue Oct 23, 2018 6:41 pm
Anyone here run the fat blade vs the Hammer (both unworked)? My merc 3 blade worked just won’t carry a load worth a crap. Thinking about getting a hammer.
Wed Oct 24, 2018 5:03 pm
Wed Oct 24, 2018 5:24 pm
Users browsing this forum: No registered users and 161 guests
