It is currently Mon Sep 22, 2025 7:12 pm
Reply to topic  [ 7 posts ]
 10x5 vs 9x8 vs 9x9 prop
Post 10x5 vs 9x8 vs 9x9 prop
Looking for pros an cons on props. Currently running a 35 hp vanguard on a Beavertail longtail with a stock 9x6 prop. Only running just shy of 18 mph and hitting rev limiter and that’s running unloaded.
So I did a little research BPS calls for a 10x5 backwaterinc recommends a 9x8 Ron hill 9x9 but that’s listed for a 27-29hp. What would give me the best speed unloaded but still able to haul a hunt load which would be me and 2 other guys maybe 3 in a pinch with guns and gear?
Thu Jun 21, 2018 8:56 am
Post Re: 10x5 vs 9x8 vs 9x9 prop
I recently got a 9x9 Ron hill prop. It looked so tiny I sent it back. Are u hex shaft or threaded?
Thu Jun 21, 2018 9:46 am
Threaded
Thu Jun 21, 2018 7:32 pm
I would run a 10x6 if your boat is heavier or if the loaded speed is more important. 9x8 Would be my pick. I'm also not crazy about a 10" prop on a 3/4 shaft. They tend to break once in awhile.
Fri Jun 22, 2018 1:04 am
Fri Jun 22, 2018 5:12 am
I've had good luck in the past going one step less pitch than what the manufacturer recommends and adding just a little cupping. You'll turn more RPM loaded and unloaded and move weight better.
-Custom pool noodle
-stage 4 water wings
Fri Jun 22, 2018 8:48 am
Fri Jun 22, 2018 7:49 pm
