It is currently Thu Mar 28, 2024 7:08 pm
[ 7 posts ] |
FireManDan1027
10x5 vs 9x8 vs 9x9 prop
Looking for pros an cons on props. Currently running a 35 hp vanguard on a Beavertail longtail with a stock 9x6 prop. Only running just shy of 18 mph and hitting rev limiter and that’s running unloaded.
So I did a little research BPS calls for a 10x5 backwaterinc recommends a 9x8 Ron hill 9x9 but that’s listed for a 27-29hp. What would give me the best speed unloaded but still able to haul a hunt load which would be me and 2 other guys maybe 3 in a pinch with guns and gear?
Thu Jun 21, 2018 8:56 am |
Will C
Re: 10x5 vs 9x8 vs 9x9 prop
I recently got a 9x9 Ron hill prop. It looked so tiny I sent it back. Are u hex shaft or threaded?
Thu Jun 21, 2018 9:46 am |
FireManDan1027
Threaded
Thu Jun 21, 2018 7:32 pm |
Will C
I would run a 10x6 if your boat is heavier or if the loaded speed is more important. 9x8 Would be my pick. I'm also not crazy about a 10" prop on a 3/4 shaft. They tend to break once in awhile.
Fri Jun 22, 2018 1:04 am |
FireManDan1027
Fri Jun 22, 2018 5:12 am |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
I've had good luck in the past going one step less pitch than what the manufacturer recommends and adding just a little cupping. You'll turn more RPM loaded and unloaded and move weight better.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Fri Jun 22, 2018 8:48 am |
FireManDan1027
Fri Jun 22, 2018 7:49 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 146 guests |
