It is currently Fri Nov 21, 2025 4:36 pm
Reply to topic  [ 6 posts ]
 37hp efi prodrive prop.
Post 37hp efi prodrive prop.
hey y'all Ive got a prop question Im hoping someone here can help with. 2017 I bought a new Gen 4 Prodrive with 37hp efi and full throttle reverse. Love the set up but ive got a pretty heavy boat so I had a shop about 4 hrs from me install a "13" hp kit so now i supposedly have a 50hp motor. Still a little slow getting up on plane but once it does it moves right a long. I want to swap the stock prop to a hammer prop but Ive heard the only way to do that is to take the bearings and gears off my Gen 4 prop shaft and press them onto a Gen 3 prop shaft. Does anyone know who I can contact to get the correct work done or is there a Hammer prop that will fit the Gen 4 Prodrive yet?
Sun Jul 08, 2018 3:11 pm
Post Re: 37hp efi prodrive prop.
What was included in a 13hp kit? It would also be cheaper and probably easier just to send a new prop to a prop shop and have them rebuild it for your needs.
Tue Jul 10, 2018 8:35 pm
Baggy in Houma can make the correct adjustments to your props that you need for your proper applications. Also, what size hull are you running?
Tue Jul 10, 2018 10:17 pm
The 13hp kit included heads, cam, intake, and"custom tuning". I'm running a 2010 G3 1756. Custom built aluminum blind from front to back along with Custom built pods on the back by marshmonster (thorn metalworks). Also is a console set up which i put the console 3/4 way up front.I carry 4 dozen duck decoys and 8 goose decoys, 1 car battery, 1 6 gallon gas tank, 1guy at 200 lbs, 1 guy at 180lbs and 1 at 250 lbs and my 65 lbs lab. With all that the boat gets on plane...the boats a rocket across the water. If i swap the 250 guy for someone around 280lbs i cant het the boat up on plane no matter what i do
Wed Jul 11, 2018 5:40 am
Move to a true mud hill style boat and I bet your performance increases dramatically.
1848 GTB, 36 PD w/ FPR
Wed Aug 22, 2018 10:49 am
Agreed that your hull is not helping things, exspecially when you say "pods". I have fought Prodrive's for a while when it comes to getting bite out of the hole. If someone does have a hammer or bblade on one I would love to hear about it. Our best results so far are with a prop a customer had Hopkins build for him. I will take a pic and add it.
Wed Aug 22, 2018 12:37 pm
