It is currently Mon Sep 22, 2025 7:03 pm
[ 8 posts ] |
jer1945
 pd clutch switch
smoked 2 switches, the clutch is drawing more then 10 amps. it still runs, but the switch doesn't last more then a sec. if i bypass it it does fine.
Tue Jan 19, 2010 12:52 pm |
stumpgrinder
 Re: pd clutch switch
think I remember someone posting that the clutch draws near 20 amps... anyone know for sure?
don't know why ur fryin da switches though...
_________________ I'm your Huckleberry......... http://www.youtube.com/watch?v=XqVe3xG-wos
I am proud to be an American, I am glad that I am free... but right now I wish I was a dog, and Obama was a tree.
Tue Jan 19, 2010 1:37 pm |
jer1945
the 10 amps it pulls is heating up the wires, i'll have to replace the clutch. is there a parts brakedown out there somewhere? jer
Tue Jan 19, 2010 5:54 pm |
cb5331
you talkin bout the pto switch? The red one? If your burnin em up like that, you have a short somewhere. Check all your wiring for a pinch or cut. Thats not normal.
Tue Jan 19, 2010 7:24 pm |
stumpgrinder
u prolly either got a short in ur wiring somewhere or in the armatuer of ur clutch.
u said if you bypass da switch da clutch works... is that when ur wiring is gettin hot? If so, that's not classified as working. lol
That circuit ain't real complicated and should be easy to troubleshoot, but we need a lil more info.
Worst case scenario you have to replace ur clutch, which takes less than an hr. with the proper tools and a hoist to lift the top side. 4 bolts to remove da top side, then 4 more bolts to remove da spline adapter from da clutch, then 1 more bolt holds the clutch on. When you remove ur clutch the last thing that comes off is a bushing/spacer..... pay close attention to which way that thing is oriented and re-install the same way. If for some reason u get it confused.... the beveled end goes towards da engine.
Wed Jan 20, 2010 6:50 am |
muddiejeep
Joined: Tue Jan 13, 2009 6:24 pm Posts: 761 Location: New Orleans, LA.
check under the engine where the wires go into the clutch assembly. thats where mine got cut and fried the wiring harness and the magnetic clutch.
_________________ When in doubt, throttle out. 18x60 prodrive w/36 prodrive
Wed Jan 20, 2010 8:27 am |
jer1945
checked the wires, they all look good. it's a new clutch, i guess.
Wed Jan 20, 2010 1:54 pm |
jer1945
found the trouble, the bearing was all but gone, just a few ball bearing left.
Thu Jan 21, 2010 10:39 am |
[ 8 posts ] |
