| Gen 1 PD Lower Shaft Seal http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=72974 |
| Author: | jpalma77 [ Fri Sep 07, 2018 8:00 am ] |
| Post subject: | Gen 1 PD Lower Shaft Seal |
After finding lots of water in my LU I changed the oil and it is no dripping from the drive shaft surface and seal on the nut. I have seen a few threads talking about part numbers and switching to 3 seals vs 2 but nothing on the actual procedure. I just ordered 2 new seals. I don't see a whole lot of info on how to swap the seals inside the nut. There is a nice GTR seal replacement thread. Is it similar to that? Find a socket that fits and tap them in? |
| Author: | dead animal [ Fri Sep 07, 2018 8:30 am ] |
| Post subject: | Re: Gen 1 PD Lower Shaft Seal |
call prodrive at 337 229-3400 and ask them. they would be happy to walk you through it. |
| Author: | jpalma77 [ Fri Sep 07, 2018 8:33 am ] |
Yeah I talked with them, they said they had a special tool to re-install them. I was thinking a socket would do the trick. |
| Author: | brycecheramie [ Fri Sep 07, 2018 3:27 pm ] |
I upgraded from the 2 seals to 3. No special tool needed. Take off prop, then I screw the seal. It’s left handed if I remember right. Order the 3 seal nut, and you should be able to send Prodrive your old 2 seal nut and they will give you a credit |
| Author: | dead animal [ Fri Sep 07, 2018 5:23 pm ] |
| Author: | banded-mallard [ Thu Sep 20, 2018 6:32 am ] |
There is no special tool. I had a gen 2 lower with the old 2 seal setup that I developed a leak. They swapped out to the newer 3 seal setup free of charge. I did install mine with a socket being very careful. Also, the newer 3 seal has a certain orientation that they have to be installed in. Can't remember, its been a long time. |
