It is currently Fri Apr 19, 2024 6:30 am
[ 4 posts ] |
Ring gear seal reverse rpm limit
Roostertail3
Joined: Sun May 22, 2016 10:32 am Posts: 334 Location: Middle ga
So I just ordered another replacement seal for my HDR. I replaced it with the newer seals when the motor had 5 hours and replaced it when I installed my mods as I slightly damaged it while removing the whole assembly. Well the new seal lasted 6 hours so I called and asked mudbuddy wtf is going on with their seals, he informed me that you are not suppose to spin it faster than 3500 rpm in reverse. Has anyone heard this BS before? I removed the old seal today and it looked new minus the missing spring inside so it wasn’t pinched or anything during installation.
Mon Nov 12, 2018 5:20 pm |
Darryle
Joined: Sun Mar 22, 2009 3:44 pm Posts: 250 Location: Fort Worth, Texas
Re: Ring gear seal reverse rpm limit
Did he give you an explanation of why you were not supposed to exceed 3500 rpm in reverse?
Sounds like a preload/sideload torque issue that the engineers didn't think thru completely, so instead of fixing the problem, they just put limitations on the product.
_________________ 2017 Atchafalaya Outdoor Designs 1244 2017 Copperhead 12hp
Wed Nov 14, 2018 5:07 am |
Roostertail3
He did not have an answer.
Wed Nov 14, 2018 6:33 am |
MaXXis85
WOW. even in forward.... that thing is still spinning at a different ratio so the seal is not stationary to the ring gear/ planet carrier. Lube the seal, clean the carrier, and use gear oil.
Fri Nov 16, 2018 7:58 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 198 guests |
