| Reverse Clutch/Brake Replacement Gatortail http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=73265 |
| Author: | xYouAreBoyx [ Mon Nov 26, 2018 9:29 am ] |
| Post subject: | Reverse Clutch/Brake Replacement Gatortail |
Running down the river the other day and heard a terrible noise. Long story short, my gatortail is stuck in reverse. The prongs on the rear clutch are all broken and I found metal shavings in the cover. What should I look for when pulling the clutch as far as damage is concerned? Any help would be great. Model is 2016 electric reverse 37 |
| Author: | Will C [ Mon Nov 26, 2018 11:49 am ] |
| Post subject: | Re: Reverse Clutch/Brake Replacement Gatortail |
Sounds like you can already see the issue. Remove the rear clutch and inspect it. Also check trans fluid for excessive metal while u are in there. Put eyes on front clutch also. Hopefully problem is only in rear clutch, this would keep the job not to hard |
| Author: | xYouAreBoyx [ Mon Nov 26, 2018 12:31 pm ] |
10-4. I'm guessing the only way to inspect the trans fluid is through the bleeder on the drum. I planned on changing it out while I'm in there anyways. I'm hoping the front is still good as it engages and shuts the engine down when I flip the switch. |
