It is currently Sun Sep 21, 2025 4:56 pm
Reply to topic  [ 1 post ]
 Go Devil LT lower seal housing overheating
Post Go Devil LT lower seal housing overheating
I have a 9HP 1999 Go Devil and just replaced the shaft. Everything is good except the lower seal housing is very hot after only a minute or so. Not sure if grease has made it all the way down there. I filled the shaft housing with grease until it was coming out of the auto lube. I may have messed up the grease seals a bit putting the lower housing on the the shaft (I did not screw it on per the directions but pushed it on).
Any suggestions?
Sat Feb 09, 2019 8:50 pm
