PD Slack when Idle causing boat to shake http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=73652 |
Author: | mguthr1 [ Tue Mar 12, 2019 7:33 am ] |
Post subject: | PD Slack when Idle causing boat to shake |
So i have a stage 2ish PD and the loping of the cam is causing some major noticeable slack between the plate that the engine is mounted on and the top half of the lower unit. I remember calling PD on this one and they said it was fine but since then I have added hydraulic steering and it is VERY noticeable now. This is a little aggravating when idling because the entire boat shakes with the lope. There is about 1" of slack and I feel that this will only get progressively worse with time. Also, when running WOT, i can look back and see the motor is a couple degrees cocked to the side while the lower unit is pointing straight due to the torque. Any thoughts on this? maybe a teflon collar in the upper half? THanks |
Author: | Will [ Sun Mar 17, 2019 5:44 pm ] |
Post subject: | Re: PD Slack when Idle causing boat to shake |
What year, how many hours? However, what you've described is normal, quit looking back, run the shit out of it. Grease the tower and it'll take some slack out. Depending on the year, the reverse gear could be adjusted a tooth to line the motor to the LU but all of the new ones I've seen with the 180* plate have the engine slightly off from the LU. Look at it from behind on the trailer and see if it's lined up. As long as there's not any play between the skeg and motor, you're fine. It's going to shake back and forth in the tower. |
Author: | Will [ Sun Mar 17, 2019 5:50 pm ] |
It's just wagging it's tail... https://youtu.be/souiF7IldNU |
Author: | Wchauvin [ Sun Mar 17, 2019 6:32 pm ] |
Yeah, it’s happy to go hunt and fish so it’s wagging it’s tail lol |
Author: | mguthr1 [ Tue Mar 19, 2019 12:13 pm ] |
2011, 400hrs....God i hate how that slack and the hydraulic steering makes the boat jarr pretty good. The steering is so rigid and the idle makes everything shake. |
Author: | dead animal [ Tue Mar 19, 2019 8:22 pm ] |
sell it and buy a gaytortail. |
Author: | Wchauvin [ Tue Mar 19, 2019 8:36 pm ] |
Stop it dead, you know you don’t feel that way lol you are speaking reckless lol |
Author: | banded-mallard [ Wed Mar 20, 2019 3:29 am ] |
do you have hydro reverse? |
Author: | MaXXis85 [ Wed Mar 20, 2019 5:09 am ] |
Ole Lopey cams! |
Author: | Russ [ Wed Mar 20, 2019 8:22 am ] |
That's the name of my motor. "The Ghost Boat ft. Ole Lopey Cam" Sent from my SM-G970U using Tapatalk |
Author: | mguthr1 [ Thu Mar 21, 2019 9:04 am ] |
Author: | Will [ Thu Mar 21, 2019 9:47 am ] |
Author: | banded-mallard [ Fri Mar 22, 2019 10:40 am ] |
