It is currently Fri Mar 29, 2024 9:58 am
[ 3 posts ] |
GTR XD lower seal part numbers for XD lower
Wchauvin
Replaced the seals on my GTR 40 XD yesterday. The seals I replaced are the ones located near the prop. To remove them, use a screw driver and lightly tap all around until you can push the bearing out. Do not hit on the bearing because you will ruin it. Once you have them out, use a socket to put the new ones back in. The part numbers for the two seals needed are as follows
- seal brand is SKF, part number 28X38X7 HMS5 RG, 1720. This seal will be the first one you put back in the cup. Make sure to put it in the same way the old one came out - the second seal is also SKF brand, part number 10930. The second seal is larger than the first so there is only one way to put them in because they taper.
Hope this helps whoever has to replace their seals on an XD.
Sat Apr 06, 2019 3:36 pm |
Full Throttle
Joined: Sun Jan 25, 2009 8:09 pm Posts: 1268 Location: North Texas
Re: GTR XD lower seal part numbers for XD lower
How many hours did you have that they needed to be replaced?
_________________ WC Custom 1854
Sat Apr 06, 2019 6:41 pm |
Wchauvin
I changed them at 75, but it was because of my mistake. I was servicing my go devil boat at the same time and when I greased the lower on the gatortail, I didn’t take out the pressure release screw and so it was operator error for the failure
Sat Apr 06, 2019 7:39 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 221 guests |
