3/4 hex prop conversion http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=73861 |
Author: | tryan [ Mon May 27, 2019 11:32 am ] |
Post subject: | 3/4 hex prop conversion |
What’s your guys thoughts on this? Would it be possible to take a 3/4 hex shaft prop and thread it to 3/4? I’m guessing this won’t work but I figured I’d ask y’all. Maybe somebody has tried it. |
Author: | Russ [ Mon May 27, 2019 11:44 am ] |
Post subject: | Re: 3/4 hex prop conversion |
We saw a big blade once that was part hex, part threads. Not sure of your reasoning for doing it, but it wouldn't be that hard if you had a halfway functional machinist floating around. Getting a new prop would probably be cheaper. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
Author: | tryan [ Mon May 27, 2019 12:44 pm ] |
I haven’t been able to find a big blade style prop in 3/4 threaded. Stock prop is undersized afternoon performance mods have been added. I’ve got throttle for days but I just don’t have enough prop now. |
Author: | Wchauvin [ Mon May 27, 2019 3:27 pm ] |
More pitch and cup would probably be your fix if you have rpms for days |
Author: | DENNYEDWARDS [ Thu Jun 06, 2019 4:54 pm ] |
I had a threaded Big Blade prop converted to a 3/4" hex shaft size. I would assume a machine shop could go the other way. I also had a machine shop make me replacement shafts both threaded and Hex. Surface drives and long tails with replacement bushings. |
